Old 10-26-2004, 08:57 PM
elaxxx elaxxx is offline
is it too big?
i just got my turbo kit today and the turbo was bigger than i though.. t70 it should still be fine if i am only pushing 8 psi right? i have a b16a with ignition upgrades and thats it.
thanks
Old 10-26-2004, 09:11 PM
Cjz89civic's Avatar
Cjz89civic Cjz89civic is offline
AF Premium User
Send a message via AIM to Cjz89civic Send a message via Yahoo to Cjz89civic
Re: is it too big?
MAKE sure you are using some sort of fuel managment before you bolt up that turbo or you will be looking for a new engine. As far as too big NEVER it will just spool later.
Mods: D16Z6 Turbo'd P28 ecu and Greddy emanage for fuel. FWD tire smoker
My first Civic love Died from 92 year old Fart not watchin out.
Old 10-26-2004, 09:31 PM
hey whats up man... it seems like everytime i have a turbo question you answer it... do you have a messeger that i could talk to you or an email? thanks man
Old 10-26-2004, 10:26 PM
1PhatCX's Avatar
1PhatCX 1PhatCX is offline
when it comes to turbos... size does matter haha
i love my td04 because its so tiny! and it should spool up fairly fast i cant wait to get everything else and get it bolted on
Old 10-27-2004, 12:21 AM
Cjz89civic's Avatar
AF Premium User
Re: is it too big?
Im on aol "cjz89civic" I dont use MSN
And size is important (hehe) a small turbo will spool faster. A bigger turbo will spool slower but make more power in the top than a smaller turbo. As far as your choice it may be alittle bigger than you will need but will make awsome power up in the high revs where the B16 preforms the best anyway.
Old 10-27-2004, 07:08 AM
redmanjd redmanjd is offline
who told you to buy that thing. And you can have a turbo to big! I suggest reading compressor maps
[IMG][/IMG]
this is th t70 compressor map,
Now for examle i have a 1.8l motor which = 110 ci
this is the equation to figure out how many cfm's your engine requires.
Pressure ratio: (14.7 + psi) / 14.7 =
so in your case 8psi (14.7 + 8) / 14.7 = 1.54
okay your pressure ratio for 8 psi is 1.54 now that is the vertical side of your compressor map.
the bottom side is you air flow (or how much air your engine requires at a certain psi by using your displacement
Air flow: (110 x 7000 x .5 x .95) / 1728 =
the first number is your ci(110) the second is your rpm(7000)
these numbers can be changed to ployt the entire map through the rpm range
so (110 x 7000 x .5 x .95) / 1728 = 211cfm
your car would need 211cfm at 0psi or n/a
to figure out how much cfm you need under a certain boost you take you pressure ratio and times it by you cfm required at 0psi.
211cfm x 1.54 =324.94cfm at 8psi
to get lbs/min from cfm you divide cfm by 14.2
324.94 / 14.2 = 22.88 lbs/min
now overlay that on the map and you will see the turbo is way to big your not even on the compressor map!! The islands in the middle is where you want to be that is max efficency its like 80 percent efficient which means cooler air you are right at the surge limit it is where you make more air thain the engine requires. Surge limit = turbo death!!!
this turbo is for high boost such as 20 to 30 psi on a large dissplasment engine like a supra or mustang.
95 b18b
new crank, eagle rods, je 10.5 : 1 pistons, 8lb flywheel, stage 3 act clutch, billet aluminium and urathane mounts, balanced rotating mass, 14.3 @ 93mph
New additions, teo4h turbo, ssautochrome turbo manifold, custom piping, turboxs bov, dsm 450cc injectors, greddy e-manage fuel controller 13.07 @ 107 untuned
Old 10-27-2004, 04:02 PM
have any suggestions for what size of turbo i get? t25?
thanks for the info
tyrell
Old 10-28-2004, 06:25 AM
what size motor do you have?
1.6l t3 60trim
1.8l t3/t4 nothing bigger than a 57 trim
and nothing smaller than a t25
95 b18b
Old 10-28-2004, 07:50 AM
DJHyperXK2004's Avatar
DJHyperXK2004 DJHyperXK2004 is offline
Send a message via AIM to DJHyperXK2004
Re: is it too big?
1.6l t3 60trim
DUDE, when I get my new engine, im def looking you up for turbo info!!!!!!!!!!!!!!!
1990 DX Hatch
17" 5Zigen Copse Rims
CIA, 4-2-1 Header
H/F Cat, 5Zigen Exhaust
Circle Earth kit
B swap in the spring???
PIX OF MY CAR
Old 10-28-2004, 09:22 AM
Re: is it too big?
i have ran into all the same problem so i know what not to do. And i am glad to help
95 b18b
