Old 10-26-2004, 08:55 PM
s10blazerman4x4's Avatar
s10blazerman4x4 s10blazerman4x4 is offline
Send a message via AIM to s10blazerman4x4
Power Window Motor
I got the door panel off and all but im havin trouble removing the bolts for the motor. The Haynes repair manual says a socket should work but those look like pop rivets to me any ideas on how to get em off? Drivin wout the door panel is real annoying.
Old 10-27-2004, 09:25 AM
Mikado14 Mikado14 is offline
Re: Power Window Motor
You are absolutely correct! They are pop rivets and you need to drill them out. Upon reinstallation, you will have to use 1/4" bolts with the NUT on the inside.
To remove the pop rivets, use a quarter inch drill and drill them out.
Old 10-27-2004, 02:09 PM
Is that like a power drill that you would use to drill holes or a battery operated one i know it sounds dumb but im puzzled
Old 10-27-2004, 03:57 PM
Fireplug Fireplug is offline
Use any type of drill you like its the bit size that matters. I always start with 1/8 drill bit then move up in size if you need to.
PLEASE MAKE SURE YOU DO WHAT Mikado14 SAID ABOUT THE BOLTS ARE YOU WILL BE SORRY.
Old 10-27-2004, 09:09 PM
will do and let u guys know im off to the jyd to find a replacement panel for that door the prev owner beat the car up pretty bad and the door panel is not reusable all bent and such and plus the wiring in those are horrible at best
Old 04-14-2005, 09:22 PM
Ok i had this link for awhile http://www.usedpartscentral.com/tech/page1.htm
and it was also posted a couple of days ago
with the new motor do i need to get bolts for the regulator or do they come with it? I saw some last week that came with it and some that did not plus is there going to be rivets on that too or screws/bolts? On this site theres bolts but it could be different. Going to make an attempt since driving 1/45 (one window 45 mph not cool) is pain
1991 Chevy S-10 Blazer 5.7 V8 RIP
1999 Chevy Blazer 2dr 4.3
