Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 10-26-2004, 07:30 PM
BeaverEater31 BeaverEater31 is offline
Gas pedal hard to push
whenever i start the jimmy,the gas pedal is hard to push.Once i press it hard,it is normal to push and the pedal is normal like it should be.Once i shut it off again to go into a store and start it,its hard to push again.i dont understand what the prob is.It only occurs when i start the jimmy,can any help or might of had this problem .
Old 10-26-2004, 11:04 PM
JackDaniels386 JackDaniels386 is offline
Re: Gas pedal hard to push
Ive got a 97 Jimmy with the same problem. It seems to me like the darn thing gets hung up on something, but i dont know. mine did it for about a week, and it even started doing it while i was going down the road and let go of the gas pedal, then tried pushing it in again. It hasn't done it for a while anymore though, but i didn't do anything to try and fix it.
Old 10-27-2004, 01:55 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
You do know on a fuel injected vehicle you don't touch the gas to start it.
Old 10-27-2004, 09:44 AM
chcknugget's Avatar
chcknugget chcknugget is offline
Send a message via AIM to chcknugget
Hey we had this problem on our safari van. It was like the pedal would get stuck in the up position. I guess you just have to get some grease or silicon spray and apply it to the cables and moving mechanism on the throttle body.
Old 10-27-2004, 06:34 PM
BlazerLT's Avatar
AF -Advisor
I think he is pushing the gas pedal while starting it and he is fighting the computer when starting it which explains why he is gets better as soon as it is started.
Old 10-28-2004, 06:59 PM
Hey blazer,i know not to hit the pedal.I`m talking about when i take off its hard to push.thnxs for reply though.Its like something is locked up when u first hit the pedal after starting it.Then its normal. ThanksAll
Old 10-28-2004, 07:04 PM
BlazerLT's Avatar
AF -Advisor
What I would do is remove the intake where it connects to the TB and make sure the butterfly is cleaned and is seating properly.
Sometimes gunk and carbon cause it to stick around the circumferance around it.
Use TB cleaner and a toothbrush to clean it.
Old 10-30-2004, 09:18 AM
BlazerLT was right, I took the intake off, and moved the throttle cable to where the butterfly opened a little, and there was a bunch of black gunk on the walls of the throttle body, and on the underside of the throttle body itself that was causing the pedal to stick sometimes. I just took a rag and wiped it clean.
Old 10-31-2004, 08:14 AM
BlazerLT's Avatar
AF -Advisor
And everything is kewl now?
Just to note, you should buy some throttle body cleaner and spary down the TB butter fly and get the under side of it also.
Most people forget about the underside.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 01-16-2005, 08:59 PM
savage8190 savage8190 is offline
I actually have the exact same problem and just narrowed it to the butterfly...guess ill go clean it now
thanks
Old 01-16-2005, 10:36 PM
BlazerLT's Avatar
AF -Advisor
Re: Re: Gas pedal hard to push
thanks
I recommend doing both sides and giving it a good scrub when wet with the toothbrush and rinsing it off.
Old 01-17-2005, 01:55 PM
blazee's Avatar
blazee blazee is offline
Problem?
My blazer was doing the same thing, it was the butterfly. I just used a tooth brush and some rubbing alcohol. TB cleaner would probably be better though. Mine still sticks a little, not as bad though, could be something else too.
Old 01-17-2005, 02:05 PM
well i went and cleaned it today and unfortunately it didnt work...its stuck really good(i literally have to kick my gas pedal to get it unstuck). This is a big problem cause once its unstuck it stays open so my rpms are rediculously high. Anyone have any thoughts on this...do i need to replace the throttle body??
Old 01-17-2005, 02:11 PM
blazee's Avatar
Problem?
When you clean it, you have to wipe away all the loose sludge. If not when you close the butterfly it will push all the sludge into the cracks and when it dries it will make it worse
Old 01-17-2005, 03:08 PM
it didnt have time to dry...because it never came unstuck.
