Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 10-26-2004, 06:37 PM
Sunliner Sunliner is offline
front end noises!
Ok you guys were so great at answering my first question, I'm gonna run another one by ya.
1997 Blazer 2wd; 110K miles
When I put 'er in reverse & cut the steering wheel to the right (as in backing out of a parking spot), there is a grinding noise coming from the front right wheel. Sound is "rhythmic" ie it is consistent with the speed the wheels are rolling, and happens whether the brakes are on or off.
Reversing to the left is no problem, & I can go forward to either direction with no problem.
I'm thinking it's the bearings myself...they're due for a cleaning/repack, & considering the mileage, I'm planning on putting in new bearings anyway. They're the original bearings & have been maintained every 30K, but I figure that's a lot of miles...
Just like to see what you guys think about the noise.
Thanks, -Mike
Old 10-26-2004, 06:41 PM
Mikado14 Mikado14 is offline
Re: front end noises!
Yep, it sure sounds like a bearing. However, and I could be wrong, but I didn't think that on a 2WD that they could be cleaned and repacked?
Old 10-26-2004, 07:46 PM
Yeah, the manual recommends cleaning/repacking every 30k.
I jacked the vehicle up last night & did the "push/pull" test, spun it and all that good stuff, without any apparent abnormality, but I still think the bearings are shot.
Can't complain though, she's gone quite a ways on them.
Old 10-27-2004, 01:49 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Doesn't sound like a bearing to me.
Sounds like the brake pads are worn out of the rear dust shield is rubbing the rotor.
Old 10-27-2004, 06:30 AM
cobra1 cobra1 is offline
check that your fan blade isnt rubbing the bottom of the fan shroud. the engine mounts sag, and it rubs, mine does it when i make a left turn.
also check that the tire isnt rubbing the inner fender anywhere.
Old 10-31-2004, 05:59 PM
Well gang...
I replaced the front wheel bearings & the brake pads this weekend & the noise is still there. Checked to see if the wheels were rubbing anywhere when turned but they aren't. I was really thinking BlazerLT was on the money with the dust shield theory, but I didn't see any evidence of it rubbing either.
One thing I noticed when the wheels were off, was a scuff mark on the stabilizer bar on the left side; looks like the inboard/front of the left wheel made contact there at some point in time. Thought maybe I was onto something since it would make sense that the left wheel goes inboard when turning right.
Well, I turned 'er hard right, got out and checked there's at least 5-6 inches between the wheel and the stabilizer...so I'm back to square one.
gotta go pull my hair out now...
-Mike
Old 10-31-2004, 06:05 PM
BlazerLT's Avatar
AF -Advisor
Did you actually push the dust shield back at all or just inspect?
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 10-31-2004, 06:30 PM
Well..I pushed on the dust shield, but couldn't get any movement. 'course maybe I didn't push hard enough...
One thing I did neglect that I wish I had checked before I put every thing back together was warpage of the rotors. My brother suggested that maybe the right one is very slightly warped & only acts up with weight thrown to that side.
Old 10-31-2004, 07:04 PM
BlazerLT's Avatar
AF -Advisor
I just had a pull brake job and had the scrape scrape scrape thing and I thought something was wrong too.
It was just the metal dust shield scraping the rotors.
Push the dust shield back with a little bit of force.
Old 02-05-2007, 03:03 AM
drfinley99 drfinley99 is offline
I'm having the same exact problem. Did you ever figure out what it was? Thanks!
Old 02-05-2007, 06:24 AM
Yep...on the left drivers wheel well there's a plastic "shroud" type thing (too early in the morning, I can't think of the right term) that keeps dirt from flying into the engine area.
It's in three or four sections, and one section had gotten a little loose and was hanging down just a little bit & was rubbing against the wheel when ever it was turned more than a few degrees. I just folded the thing back at first for troubleshooting & later trimmed it just a little, and no noise since!
hope that helps!
-Mike
For reference:
2006 TrailBlazer LS
I6 2wd
Automatic trans
~72 k miles
I miss my '97 Blazer...
Old 02-05-2007, 08:22 AM
ZL1power69's Avatar
ZL1power69 ZL1power69 is offline
GM S-Series Mod
guys this thread is over 2 years old. please refrain from posting in old threads.
2000 Chevy Blazer ZR2
Performance Mods: Numerous
Suspension Mods: Some, but not enough
Exterior Mods: Just Right
1987 Buick Turbo T Dark Red
Low 11 sec sleeper
.030 4.1 block, PT6262E, & other odds and ends....
My Cardomain
Closed Thread
