| Off-Topic Talk about anything other than cars. |
hard 2 start any help?
my 99 eclipse gs 2.0 non turbo anninversary edition is very hard to start,takes about four or five key turns.then fires up but idles rough for about 2 minutes.then once warm runs perfect.please any help at the end of my rope.replaced idler control,throttle position control.and ect sensor.and spark plugs.
Re: hard start
Sounds like the same problem I was it having. It was my coolant temp sensor. It was hard as hell to start when it was cold. Once it fired up, it idled a little rough untill operating temp was reached. Its a cheap fix if thats it, but the wires on mine were just lose so I f*cked with them a little and it fired right up. Also is your check engine light on... cause I know when the wires on mine would get lose it would come on... when I messed with it, the light would the light would shut off..
AWD sold New car* 90' Eclipse Gs-T Shaved head with rebuilt motor Slowboy racing limited slip compression 165 across the board (: Fully ported Big 16g with 34mm flapper Precision racing Fmic Slowboy Boost controler set at 15lbs Custom 3 inch turboback Fully ported o2 housing Ported 2g manifold Slowboy racing UICP 3 inch hard intake pipe SAFC Autometer carbon fiber gauges Putting down a solid 300whp 1/4=13.7 at 109 That mph is good for high 12's with traction (: |
thanks bro
i replaced the coolant temp sensor,but i never get a check engine light.
different car, same problem. I have a '91 non-turbo talon, and it has hard starts too. I get a CEL for the first like 5 seconds, then it disappears. My idle isn't very bad, it just takes a while to start, one key turn, but i must hold it for about 3 seconds(imagine three seconds, and you'l lunderstand thats a long time).
