Old 10-26-2004, 05:10 PM
jackmalone2001 jackmalone2001 is offline
she shakes when I brake!!!
Hey all--
I have a serious shaking in my front end only when I use the brakes. I have noticed this problem for a while and thought maybe it was tires out of balance. They were getting old any way so I got new tires and still shaking when braking. haha
I thought it might be tie rod--but it doesn't shake when driving or cornering only when I brake.
I was thinking maybe the rotors might be warped?
The guy at the tire shop said it could be lower ball joint...
before I go out and buy...
two tie rod ends
two lower ball joints
two rotors
new pads
Any ideas?
before:
after:
Old 10-26-2004, 05:36 PM
DaMoNe6969's Avatar
DaMoNe6969 DaMoNe6969 is offline
Re: she shakes when I brake!!!
My guess is the rotors are warped.. Take them in and get them turned, As long as it hsant been done too many times.. Its like $10cdn a rotor here
1991 Camaro Z28
Old 10-26-2004, 05:41 PM
so you dont think it has anything to do with the ball joint or tie rod ends? Where do you take rotors to be turned? Or should I replace (new ones are like $20US)
before:
after:
Old 10-26-2004, 06:42 PM
Dober89 Dober89 is offline
rotors are almost always the problem
Old 10-26-2004, 08:00 PM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
i would say its the warped rotors you have on the front end, might want to have those looked at
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
Old 10-26-2004, 09:59 PM
Chevyracincamaro's Avatar
Chevyracincamaro Chevyracincamaro is offline
i agree on the rotors. i would seriously just buy new ones, they arent that much more expensive than turning and you get brand new ones which will last longer in the end...
*Better power-to-weight ratio than a C6 corvette*
Old 10-26-2004, 10:56 PM
Genopsyde's Avatar
Genopsyde Genopsyde is offline
The President
Send a message via AIM to Genopsyde Send a message via Yahoo to Genopsyde
yea, buy new ones, but hang on to the old ones, so when the new ones wear down or start to warp, have the old ones turned, then put them back on. That should save you time, money, and make both sets last longer.
Old 10-28-2004, 03:08 PM
so you guys dont think it could have anything to do with the lower ball joints or the tie rods?
before:
after:
Old 10-28-2004, 03:19 PM
im sure it could, but im 90 percent sure its your rotors. see if you can get a micrometer and measure any inconsistancy in the rotor surface. i measured my sister's out a couple weeks ago and hers were off by 1.5mm in some places. it was bad...
Old 10-28-2004, 03:24 PM
SMOKEY818 SMOKEY818 is offline
just get some good rotors, i heard bad things about the crossed drilled they said they crack, just get the ones that have dimples
89 Camaro with lt1/t56/headers,borla exhaust,ac delete, march pulleys, slp CAI,3.73 gears,msd ignition,port & polished heads, reprogrammed pc, free mods, hotchkis suspension,sub-frame conn & weight reduction.
Old 10-28-2004, 05:23 PM
crossdrilled rotors may crack but only if you buy crappy ones off ebay. If you put out the money for a good set of brake rotors and pads they are going to hold up.
Old 10-28-2004, 06:19 PM
Genopsyde's Avatar
The President
if it was ball joints or tie rod ends, it'd most likely shake when you aren't braking as well.
Old 10-28-2004, 08:40 PM
89IROC&RS's Avatar
and geno nails it right on the head
Old 10-28-2004, 10:55 PM
*applauds geno*
Old 10-29-2004, 07:25 PM
thanks guys...new rotors it is
before:
after:
