Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 10-26-2004, 04:57 PM
Advocate(NYT) Advocate(NYT) is offline
Turboing a '95 Talon ESI
I looked at the stick thread at the top of the page, but no one seemed to reply to it, basically im wondering if the talon's esi engine could withstand being turbochared, and how much it would cost me to turbo it professionally, what about the parts? (im guessing all prices will be in american). How much horsepower would it add? i'm looking to squeeze as much hp into it as possible.
thanks
a
Old 10-28-2004, 11:45 PM
Re: Turboing a '95 Talon ESI
upppppin
Old 10-29-2004, 08:32 PM
97_3clipse's Avatar
97_3clipse 97_3clipse is offline
Send a message via AIM to 97_3clipse
what is it like around ,8 psi the 420a can hold?
1998 Eagle Talon TSi AWD
6 Bolt Swap \ DSMLink V2.5 \ ACT 2100 clutch \ PTE SCM 61 \ Forge MBC@28psi \ VPE O2 Housing \ MR Downpipe \ Thermal R&D Cat-Back \ Tial 38mm WG dumping off O2 \ FMIC w\ in short route \ AFPR setup/walbro 255hp \ PTE 880cc injectors \ Crower Ti retianers \ Crower Springs \ Crower 64414 (stage 3 race) cams \ Ferrea valves \ 3.5 bar MAP \ PLX M-300 Wideband
Old 10-31-2004, 11:52 AM
how much am i looking at to do it myself or to do it professionally.
Old 10-31-2004, 11:57 AM
97_3clipse's Avatar
go to www.hahnracecraft.com they make a complete turbo kit for an 420a motor.
Old 10-31-2004, 06:35 PM
george536's Avatar
george536 george536 is offline
Stickies up top explain most of this.
-1997 Eclipse Spyder GST |Stock|
-1990 Eclipse GSX
|ACL Main & Rod Race Bearings|Balance Shafts Removed|ARP Head Studs|Cometic HG|FP 20g TDO6H|EPROM Chipped (stutter box 5k, fuel comp.)|PTE 680cc inj.|Walbro 255 HP Fuel Pump|Autoteq FPR|SAFC 2|FMIC|2g MAF|Dejon Tool Hard Pipe|Greddy Type S|MBC at 17PSI|Ported 2g Exhaust Manifold|02 Housing w/ Tial 38mm WG|Full 3inch Exhaust w/ Y-pipe Cutout|Fidanza Flywheel|ACT 2100|4 Bolt LSD Rear|Poly Mounts|KYB AGX Suspension|Roll Bar|
Old 11-05-2004, 07:13 PM
exe2000 exe2000 is offline
any body knows what upgrades before turbocharging an talon esi
Old 11-06-2004, 12:31 AM
george536's Avatar
You dont need no internal upgrades if your gonna run like 8 psi. If your gonna run over 10 then your gonna need upgrades. Read the stickie up top please. it talks all about turboin the 420a. Most ask questions can be answered in there. And if you have a question thats not in there. Post in that thread and Eclipserst (jake) Checks it often and will answer your question.
-1990 Eclipse GSX
Old 11-08-2004, 08:39 AM
Cool Re: Re: Turboing a '95 Talon ESI
before turboing do I need injectors for the 14.7:1 or the fuel pump upgrade
Old 01-29-2005, 10:09 PM
fiberglasscivic's Avatar
fiberglasscivic fiberglasscivic is offline
Send a message via AIM to fiberglasscivic Send a message via Yahoo to fiberglasscivic
you need both if your boosting over 10psi. I would suggest the injectors at least if your do anything less.
