Old 10-26-2004, 03:03 PM
ChrisNJ ChrisNJ is offline
Any known trunk leak problems? 99
have a 99 ultra for a year. can't seem to fix trunk leak around rear most lower weatherstrip area. water getting under the weatherstrip in 2 places about 10" right and left from the center hold down loop. previos owner has caulked everything including under the weather strip to no avail. trunk looks aligned, compared to my 00. just hoping it is a a known issue with a fix? it leaks enough after one trip in the rain to form a puddle in the spare tire area, just keep soaking it up for now.
Old 10-26-2004, 08:58 PM
vljenewein's Avatar
vljenewein vljenewein is offline
Banned
Send a message via ICQ to vljenewein
Re: Any known trunk leak problems? 99
Also you might try checking the fender wells for a hole. I have a 1993 and when I got it it leaked in the spare tire well badly, and I looked under the carpet and there was a hole about 3 inches across and about 4 inches long. Every time I would drive it in the rain, the water from the tire would fly up and into the hole and it quickly accumulates. Fixed it with plastic, bodyputty and bondo.. then 2 cans of undercoating spray. I did not want any recurrence. ANY little hole will let in quite a bit of water over a very short time.
Old 10-27-2004, 04:36 PM
sega's Avatar
sega sega is offline
my 92 lesabre has a hole in its fender well and it gets the backseats wet from water splashing out of the spare tire well.
Old 10-27-2004, 05:33 PM
ks0309 ks0309 is offline
mine was leaking from water getting on top of brake light assembly and leaking behind it , then going into trunk. check seal around lights. (1992 Park ave.) 170,000 miles . runs excellent
Old 11-30-2004, 10:07 AM
Smitty52 Smitty52 is offline
Trunk Leak
I am on my third Park Avenue and everyone had a trunk that leaked.
Two different 96's and now a 2000.
I have never been able to permanently solve the problem so yes, I would say this is a known problem.
Old 11-30-2004, 02:37 PM
aarcuda aarcuda is offline
i have the problem in my 95. passenger side corner of the back window. i wish I knew how to fix it
Old 11-30-2004, 05:04 PM
vljenewein's Avatar
Banned
I also had leaking from around the left rear tail light housing. Using silicone sealant/glue really helps.
Old 12-19-2004, 02:22 PM
91pa 91pa is offline
I've got a 91PA and there is water coming in the driver's window (somewhere) and it ends up in the floor of the back seat... any help?
Old 12-21-2004, 06:21 PM
tompressman tompressman is offline
Yes I had the same problem.....93 Park Ave. Car stunk when I bought it from water....Pulled out the entire tail light assembly and re sealed all around the factory rubber gasket including the bolt holes going into the trunk....all betta.
Old 12-22-2004, 09:09 AM
we'll, the car got hit a few weeks ago, and I asked the body shop to look into it for me, whil it was there (got hit in the front). He put a guy IN the trunk and started spraying water. Found it in a jiff, fixed with silicon. Yeahhhhhh
