Go Back   Automotive Forums Car Chat > Dodge > Durango
Old 10-26-2004, 02:52 PM
dodge lovin' girl dodge lovin' girl is offline
Water Leak under passenger dash???
Help!!!! There's a water leak coming from somewhere under my passenger dash area. I can't find the exact place where all the water is coming from. I notice everytime I leave my car out in the rain, there's a puddle of water on my passenger floor. I suspect that this is the cause of my infinity amp being fried a month ago. Anyone else having similar problems???
Old 10-30-2004, 03:49 AM
speed_freak's Avatar
speed_freak speed_freak is offline
Send a message via MSN to speed_freak
Re: Water Leak under passenger dash???
ive got the same problem in my 1500 ram, just havent taken the time to figure out what the problem is
Old 11-05-2004, 12:28 PM
When you figure it out, let me know.
Thank you.
Old 12-27-2004, 02:30 PM
jonheu jonheu is offline
Its from the AC line
Old 01-01-2005, 11:47 AM
telemarkdude telemarkdude is offline
I had this problem too. Was a leaky windshield wiper hose. Turn on the washer and keep it depressed for a bit while someone checks for leaks. Look both under the reservoir as well as through the grille just under the windshield on the passenger side. If there's a leak you will see liquid squirting as well as the dripping below.
Old 04-28-2005, 11:19 PM
MIKES87GNX MIKES87GNX is offline
Thats Your Heater Coil Good Luck Replacing It
Old 04-29-2005, 08:37 AM
DurangoDave DurangoDave is offline
Re: Re: Water Leak under passenger dash???
She said it's rainwater on the floor, not coolant. It's not the heater core.
Old 07-19-2005, 08:38 PM
Black Dog Black Dog is offline
Send a message via MSN to Black Dog
Lightbulb Re: Water Leak under passenger dash???
Ok I have the same problem, and belive me is no big deal, the probem is that the gasket from your air intake (fresh air mode on your A/C) have a crak, and/or the drain hole of the A/C system is not working properly, take it to a A/C especialist to fix that, its not gonna take you more than 50 bucks and you´re goin to wait like half a day for that job.
Good Luck.
Old 09-22-2005, 11:15 AM
southe southe is offline
I have a 1999 Dodge Durango that does the same thing. My ABS light stays on all the time, mechanics don't know what is causing that.
Old 10-13-2005, 06:52 PM
Rampa250 Rampa250 is offline
There is a Technical Service Bulletin on 2001-2003 Durango's. It says water may enter the passenger compartment between the HVAC housing and the bulkhead. A foam seal is used to seal the heater housing and the bulkhead. Condensation from the A/C evaporator can run along the evaporator drain tube and enter the passenger compartment if the seal between the HVAC housing and the bulkhead is not sealed properly. This will result in wet passenger compartment carpet when the air conditioning is operating.
Repair Procedure:
Locate the evaporator hose and drain tube opening in the bulkhead at thje rear of the engine compartment. Apply a bead of RTV sealer, p/n 04467708or equivalent, to the perimeter of the opening to seal the joint between the bulkhead and the HVAC gasket and the joint between the drain tube and the HVAC gasket.
No extended warranty, your on your own, no support from Dodge
