Old 10-26-2004, 01:51 PM
dampachi's Avatar
dampachi dampachi is offline
Banned
Send a message via AIM to dampachi Send a message via MSN to dampachi Send a message via Yahoo to dampachi
Grrr second gear
I just recently bought a 2002 mustang GT 5spd...and just today I noticed when I shift second gear I can feel like a grinding feeling in the shifter and it makes a sound. and one time...it popped out of second gear causing me to grind it. It only does this 3 out of 5 shifts. It's like a crunching sound. So...if any has anything to say please comment! Thanks!!!!
Oh yeah...it's still under factory warranty. Thanks!
Old 10-26-2004, 01:56 PM
andrewespo's Avatar
andrewespo andrewespo is offline
Re: Grrr second gear
Bring it to the factory tell them your problem. Sounds like a syncro problem, basically the syncros might not be lining up causing it to grind.
1988 Mustang 5.0 5spd/CAI,BBK 65mm TB,BBK underdrive pulleys, Flowmaster catback, E303 cam, headers, mass air conversion, Steeda tri ax shifter, 3.73 gears, Trick Flow street intake, 3g 130 Amp Alt.
Old 10-26-2004, 03:07 PM
Ghost96Gt Ghost96Gt is offline
Send a message via MSN to Ghost96Gt
yeah it sounds like u have a worn out synco my 2ed and 3rd do that. try when u are shifting to bring it out of first then put it in nuetral release the clutch then push the clutch back in and put it in 2ed (double clutching i think is what it is called)
Old 10-26-2004, 06:13 PM
dampachi's Avatar
Banned
Yeah that's what I've been doing. but it needs to be fixed.
Old 10-26-2004, 06:55 PM
stang_racer20's Avatar
stang_racer20 stang_racer20 is offline
Send a message via Yahoo to stang_racer20
I definitely sounds like syncros. I was gonna say it could be a misadjusted clutch, but then it would most likely do it throughout all gears. If its still warranteed then take it back and have em fix it. Gotta take advantage of the factory warranties. If its real bad, they'll probably give you a new trans too. We do a lot of that where I work.
92 Mustang GT, 347 Stroker(Forged Steel Crank/Rods-Balanced, Forged Alum Dished Pistons), B50 Block, Track Heat Intake, Twisted Wedge Heads w/ Stage 3 port/polish, 80mm C&L MAF, FMS 30# Inj., BBK AFPR, Trick Flow Stage 2 Cam, Trick Flow 1.6R Rockers, BBK EL-CC Headers, MAC O.R. H-Pipe, Flowmaster Cat-Back, Accufab 75mm TB, MAC CAI, BBK Pulleys, Griffin Alum Radiator, Mark 8 Fan, MSD Pro-Billet Distributor; AOD, Dynamic 3300 L-U Converter, B&M Trans Cooler; 3:73 gears.
Old 10-27-2004, 09:30 AM
u can always rebuild the tranny buy a rebuild kit, take it to a tranny shop have them drop it out for u and then take it home a rebuild it.
Old 10-27-2004, 07:01 PM
dampachi's Avatar
Banned
wow...today. it didn't do it at all. even under hard accelerations. it shifted fine even when i was getting rubber in second. does anyone know what to make of this?
Old 10-27-2004, 09:46 PM
MARS's Avatar
MARS MARS is offline
Re: Re: Grrr second gear
O......K..... but doing that would defeat the whole purpose of having a warranty!
Old 10-28-2004, 01:44 PM
dampachi's Avatar
Banned
Yeah it would. and it started doing it again this morning.
Old 10-28-2004, 08:59 PM
andrewespo's Avatar
With the syncros it's hit and miss sometimes the gears will go in everytime, other days the gears will grind in the same spot. Sooner or later it will get worse, with more consistent grinding.
