Old 10-26-2004, 01:32 PM
Technical_Automan Technical_Automan is offline
Banned
Exclamation Help Me Start My Car Please!!
I just finished up my automatic to 5-speed manual conversion on my '94 SL and the only problem that I have is starting the car. As you very well may know with an automatic, the transmission needs to be in either neutral or park to start the car. Well now that it is manual, it should be that the clutch needs to be pushed in, but I don't see a plug to go into the clutch neutral safety switch! And the car won't start when I turn the key, of course. If anyone can tell me which wires can be crossed to bypass the neutral safetey switch, or give me a wiring diagram of the system I would really appreciate it!! Thanks.
ps - are the wiring harness's different between manual and automatic does anyone know? (everything else that I thought would be a problem had a plug that worked)
Old 10-26-2004, 02:50 PM
Igovert500's Avatar
blue + red light magnet
Re: Help Me Start My Car Please!!
Well I'm looking for your answer...but if I can't find anything, you may want to call:
Kormex Transmission Parts
2020 S. Vineyard Ave.
Ontario, CA 91761
800-429-5464; 909-947-0569
ask for Frank Martin
I got that off Jeff Lucius's site (www.stealth316.com)
He knows our trannies.
Also you could try a search on 3si, I'd assume someone there has done the auto to manual swap.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 10-26-2004, 03:18 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: Re: Help Me Start My Car Please!!
Hehe yeah definitely check 3si. When it comes back up. Mikes95RT is the guy to talk to. I think he posted a thread on exactly what you need to do to get your back up lights to work and to get the car to start.
Old 10-27-2004, 11:02 AM
Banned
I would check 3si, but it won't let me sign up for some reason, so I can't do a search for anything...so no one here knows? igovert did you find anything yet? i appreciate you looking for me.
Old 10-27-2004, 11:22 AM
Stealthee's Avatar
I can probably guess why it wont let you sign up. You can't use free web mail such as yahoo or hotmail. It has to be something like aol or verizon or something like that. The site is still down but it is being worked on right now so hopefully it will come back up shortly and you can find the info you need.
Old 10-28-2004, 08:46 AM
BB1970's Avatar
BB1970 BB1970 is offline
how many wires going to the switch?
1993 Mitsubishi GTO Twin Turbo (RHD) NOW SOLD!!!
9b turbos with manual boost valve mod set @14psi
turbo xs type h-rfl blow off valve
blitz dome filter
sachs clutch
completely de-catted
fuel pump voltage rewire mod
ebc redstuff front brake pads
greddy fully automatic turbo timer
now drives a sensible family sedan. A 340hp 1997 mitsubishi evolution IV
Old 10-28-2004, 04:04 PM
Igovert500's Avatar
I have found absolutely nothing..but I havn't checked 3si...
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 10-28-2004, 04:06 PM
Stealthee's Avatar
3si is still down. Acording to them it will be back up sometime tonite. If you still have trouble trying to sign up let me know and I will try to contact the Mod. for ya.
Old 10-28-2004, 07:02 PM
Banned
Yeah, I only have the free email services...well from the clutch pedal neutral safety switch there are two wires that go into the plug, so I assume there are two wires and a plug that should come out of the harness on a normally manual 3S. But since my was automatic I don't have the plug, or at least I can't find it up there. Does anyone know for a fact that the wiring harness's are different between automatic and manual? I don't see why they would be, everything else was made universal (crankshaft, tranny bolts, console, firewall, etc..). I did find a wiring diagram but it doesnt say anything about the neutral safety switch. I tried hotwiring the car today, I could get power to all the systems in the car without the key in, but I didn't have enough hands to connect the wires that might start it at the same time. But I don't think that would work anyway. As for starting it from the starter, I took off the starter and tested it off the car to see what was going on when I crossed the wires on it...off the car it functioned properly (the gear pops out and then spins where it would contact the flywheel), but when I put it back on the car and crossed the wires it spins first and then pops out, making it just knick the outer edge of the flywheel instead of engaging it. If anyone that has a manual could get under the dash and look at their clutch pedal to see where the plug that plugs into the neutral safety switch on the clutch pedal goes to (mouthful) and tell me what color the wires are that go up into the harness, I think i'd be able to get the car started with ease. Although in the end I may end up having to put in a hidden push button starter, which would still be cool. Please someone, this is all I have left to do on my auto to manual conversion!!!!!
Old 10-28-2004, 07:08 PM
Stealthee's Avatar
The wiring harness is for sure different between manual and auto. 3si is back up now so if you go over there search for the post by Mikes95rt. Hes a genius with these cars.
Old 10-28-2004, 07:45 PM
Banned
omg I read through his post's and he knows exactly what i'm asking!!!! BUT I can't log in to ask him because of the mail thing!!! omg omg omg lol I want to ask him so bad, I've been struggling with this thing for too long. Can anyone ask him for me, or get him to come over to AF so I can talk to him? MAN OH MAN PLEASE SOMEBODY HELP ME OUT HERE!! rofl
Old 10-28-2004, 08:03 PM
Stealthee's Avatar
I'll see if I can get in contact with him. I'll tell him about your issue and see if he can help ya. I cant promise anything though but I'llsee what happens.
Old 10-28-2004, 09:39 PM
Banned
thanks a million man, I really appreciate you trying.
Old 10-28-2004, 11:17 PM
Stealthee's Avatar
I PMed him. Hopefully he gets back to me shortly.
Old 10-29-2004, 11:33 AM
Stealthee's Avatar
Re: Re: Re: Help Me Start My Car Please!!
You got PM's Tech.
