Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 10-26-2004, 11:45 AM
peterie peterie is offline
b16 head on h23??
hallo,
kan i put a b16a or b16a2 head on a h23 block. If yes, is b16 head differen from h22 head?
how much hp kan i make out of h23 with vtec head?
thanks,
Old 10-26-2004, 01:27 PM
93/01alaLUDE 93/01alaLUDE is offline
as far as i know you cant put a bseries head on a h series block...if you want to make your car vtec just get a h22 vtec head and put on it...you can get one for about $200 on ebay
Old 10-26-2004, 02:54 PM
CivicEXdude CivicEXdude is offline
No, you can't put a B16 head on a H23 or any H series...only a B series.
Old 10-26-2004, 10:15 PM
G3_preludeSI G3_preludeSI is offline
Send a message via AIM to G3_preludeSI
Re: b16 head on h23??
yea band h series blocks are diffrent, just look for a h22a1 head and stick it on there
Old 10-27-2004, 03:10 AM
What do i need to replace to make the hole thing work, like a h22 ecu or after make ecu for v-tec, h22 timing belt.
Old 10-27-2004, 11:11 AM
Phunyguy Phunyguy is offline
Send a message via AIM to Phunyguy Send a message via MSN to Phunyguy Send a message via Yahoo to Phunyguy
H22A1 head - wiring for vtec solenoid - P13 ECU - and lots of HIGH octane gas cause your compression ratio will be through the roof. you are better off just swappin in a complete H22 - fewer problems - safer engine - almost the same hp gain.
Old 10-30-2004, 12:21 PM
h22_pReLuDe h22_pReLuDe is offline
Send a message via AIM to h22_pReLuDe
i got a question.......can not using high octane fuel in my 94 prelude (h22) cause me to spin a bearing in the block.....if not what do you think could have?
Old 11-04-2004, 11:34 AM
ShoofIsLudin ShoofIsLudin is offline
Re: Re: b16 head on h23??
check your oil and don't go past redline
Old 11-06-2004, 10:51 AM
Re: Re: Re: b16 head on h23??
even if it is spoon chipped.....i had lots of oil but i was running this other car takin it to like 8000rpm......?
Old 11-08-2004, 10:56 AM
AcesHigh's Avatar
AcesHigh AcesHigh is offline
Prelude Guy
Send a message via AIM to AcesHigh
The Spoon chip allowed you to take the engine to a higher RPM. This does not neccesarily mean that it is safer to do so. The Spoon chip killed your H22A.
1993 Mazda Rx-7 Touring
Ricer Extraordinaire
Old 11-08-2004, 02:34 PM
Question Re: Re: b16 head on h23??
damn that sux......now i need a block....and i don't know where to get one for a good price.....
