Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Audio and Videos
Old 10-26-2004, 10:37 AM
real_madridcf's Avatar
real_madridcf real_madridcf is offline
Send a message via AIM to real_madridcf Send a message via MSN to real_madridcf Send a message via Yahoo to real_madridcf
Need Help w/ new Stereo
I had taken the stereo from the gst and put it into the n/a, and i finally called to get the stereo code. Well i called one of the dealers ashal mentioned (thanks man), and got it. So the stereo seems to work fine but no sound is coming out of the speakers. Does anyone know if this is a general prob? Cuz the stereo itself works perfectly fine, when i put a cd in it reads it and all but no sound. I'll try to play around w/ it a little more today as well.
Any help is appreciated!
95 Eclipse GS: OBX Full Exhaust System, OBX Headers, OBX Short shifter, OBX Spark Plugs & Wires, 17' MSR Rims w/ Wanli tires
96 Eclipse GS-T : K&N Filter w/ Hardpipe, UICP & LICP, Greddy Type S bov, Greddy Boost Gauge
Hala Madrid!
Old 10-26-2004, 03:03 PM
duckydsp's Avatar
duckydsp duckydsp is offline
Did you make sure everything in the back is plugged in? You should check all of the wires and make sure they are matched up.
DSF
1998 Green Mitsubishi Eclipse GS- Vibrant Ram Intake, Greddy Evo2 cat-back, front and rear strut bars.
2 Kicker L7s, amp coming soon
17" white Motegi RT5 rims, Quwhees 12-piece wide-body kit will be put on....... someday
Old 10-26-2004, 03:33 PM
george536's Avatar
george536 george536 is offline
Re: Need Help w/ new Stereo
umm what about the volume j/k
it should only do that if the wires aint connected rite.
-1997 Eclipse Spyder GST |Stock|
-1990 Eclipse GSX
|ACL Main & Rod Race Bearings|Balance Shafts Removed|ARP Head Studs|Cometic HG|FP 20g TDO6H|EPROM Chipped (stutter box 5k, fuel comp.)|PTE 680cc inj.|Walbro 255 HP Fuel Pump|Autoteq FPR|SAFC 2|FMIC|2g MAF|Dejon Tool Hard Pipe|Greddy Type S|MBC at 17PSI|Ported 2g Exhaust Manifold|02 Housing w/ Tial 38mm WG|Full 3inch Exhaust w/ Y-pipe Cutout|Fidanza Flywheel|ACT 2100|4 Bolt LSD Rear|Poly Mounts|KYB AGX Suspension|Roll Bar|
Old 10-26-2004, 06:39 PM
lol, I made sure all the wires are connnected right. Maybe i got a short circuit? And yes George it tried turning the volume up. lol
Hala Madrid!
Old 10-27-2004, 05:01 PM
duckydsp's Avatar
Yeah, I think that it might be a short in one of your wires. You should check to see if your wires have power in them.
DSF
Old 10-28-2004, 12:26 AM
george536's Avatar
hey i need the stereo code for my stock tape player. where do i call? and what info do i give em? vin?
-1990 Eclipse GSX
Old 10-28-2004, 07:24 AM
Ashal(ashah000), a while back, posted a few dealers that will do this for you. I personally called Moran Mitsubishi (248-353-0910). The guy only asked for my serial # on the stereo and 2 mins later he gave me the code... FOR FREE!! Other places might ask for the vin too.
Hala Madrid!
Old 10-28-2004, 10:33 AM
GSTRacerNVUS GSTRacerNVUS is offline
If its not a short maybe its a bad fuse?
97 Eclipse GST MT
Race Every Day Like It Will Be Your Last.
My one insignificant mod: Dump Tube - CUT
Old 10-28-2004, 01:29 PM
duckydsp's Avatar
If it was a fuse, power wire, or grounding wire then the stereo wouldn't turn on at all.
I'm not positive, but I'm pretty sure that the stereo code should be under the stock player.
DSF
Old 10-28-2004, 05:31 PM
george536's Avatar
i got it here 805 650 8118
-1990 Eclipse GSX
Old 10-28-2004, 07:27 PM
xavier3jr's Avatar
xavier3jr xavier3jr is offline
Send a message via AIM to xavier3jr Send a message via MSN to xavier3jr
u didnt get the continuous power and ACC mixed up did u?
96 GS - 5 Speed-Sold
1998 Ford F-150 XLT 4X4
Old 10-29-2004, 09:25 PM
BlackShadowTSi BlackShadowTSi is offline
Send a message via AIM to BlackShadowTSi Send a message via MSN to BlackShadowTSi Send a message via Yahoo to BlackShadowTSi
i guess that you used the stock connector of the car (the white one with all the cables for the speakers and everything), but don't forget to connect the one that goes to the amplifier under the passenger sit (is a black cable with a connector similar to the ones of the old pc keyboards) , if you don't plug that one you will never hear anything.
And if you cut the cables of the N/A to put the same "white" connector of the gs-t check the pingout again.
Diego Fontán
Eclipse GS-t ==>AWD
12.12 @ 113.xxmph
60' 1.76
Check My GS-T ==> AWD project
car's video: http://cssteam.com/gstx.wmv
At the track: http://videos.streetfire.net/video/aad4c670-6066-44d5-b6f6-c04346cb8407.htm
Old 10-29-2004, 10:59 PM
duckydsp's Avatar
I've never used the one under the passenger seat and all of my stereo's worked fine. I was under the impression that it was for power seats or something like that.
DSF
Old 10-29-2004, 11:23 PM
well i already had the same problem with the stereo of my last tsi awd,i had no sound till i plug that black connector
Diego Fontán
Eclipse GS-t ==>AWD
12.12 @ 113.xxmph
60' 1.76
Old 02-21-2005, 06:55 PM
UPDATE:
This thread is from a while ago but if you can beleive it i havent got it fixed! Yup ive been driving around with no sound for a while now. I have a question about something someone told me. I talked to one of my automotive instructors about this problem. The thing is before i put the code in i had tried several other times with random # and after the 3rd try it said error and wouldnt let me try any more, unless i unplugged the system and replugged it.
My instructor told me that if you entered the code wrong 3 times that the error would occur and it would burn a fuse so that the player wouldnt work whatsoever!
Has anybody ever hear of anything like this? Any help is appreciated!
Hala Madrid!
