Go Back   Automotive Forums Car Chat > Honda > Integra
Old 10-26-2004, 08:38 AM
DJHyperXK2004's Avatar
DJHyperXK2004 DJHyperXK2004 is offline
Send a message via AIM to DJHyperXK2004
I got a 91 LS Teg...
And want to swap out that engine that’s in the Teg with the pos in my civic.
Is it a good engine to swap in??? On the other hand, should I just sell the car and get another type of engine? The car only cost me 500 and comes with everything, including a rear disc upgrade as well for the civic
I just want to know if the B16a?? is that what’s in there, is a good motor to start with.. and while its out of the Teg, should i have anything done before installed into the civic
can these engines handle a small amount of boost, like 7-10 psi, nothing crazy
Id figure the teg guys over here might knows some stuff about there ls engines
1990 DX Hatch
17" 5Zigen Copse Rims
CIA, 4-2-1 Header
H/F Cat, 5Zigen Exhaust
Circle Earth kit
B swap in the spring???
PIX OF MY CAR
Old 10-26-2004, 04:35 PM
shyfty50 shyfty50 is offline
First off the engine is a B18A1 - 130hp, 122lbs/tourque. Definatly a solid engine for boosting depending on its condtion, miles, etc. You prolly wanna do a compression test on it before you get into anything serious. Iv' seen stock B18A's run 12psi for 150,000+ mi with no problems but the engine was in pristine condition when he started.
Old 10-26-2004, 06:21 PM
Re: I got a 91 LS Teg...
so what should i do with the engine while I have it out....its got a 140,000 miles on it
like, before putting it in the civic, should i have any thing done to it???
1,000 is my budget
some people said sell the teg for 3,000 and get an engine
but id figured that the one in the ls was good to build up
1990 DX Hatch
CIA, 4-2-1 Header
Circle Earth kit
PIX OF MY CAR
Old 10-27-2004, 09:39 PM
140k is a bit steep, if you haven't already taken out the engine get a compression test done to check for leaks. However selling the teg and getting a brand new B18 and using the left over money to build and boost kinda sounds like a better idea than trying a 140k engine. Any maintanance that needs to be done is alot easier while the engine is out seals, gaskets etc. Especially check the cam seal in front of the distributer as it likes to harden and leak in B-block engines. You also might want to check into seeing if the water pump, timing belt and timing belt tensioner have been replaced becasue those tend to go as well. Other than that I suggest cleaning every square inch of it before dropping it in.
