Old 10-26-2004, 08:25 AM
mtrotter70 mtrotter70 is offline
Disable door chime?
Is there a way to disable or turn off the door chime, without messing
up any other electrical components, like power windows,locks etc.
95 S10 Blazer LS.
Old 10-26-2004, 05:29 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: Disable door chime?
Close the door?
Old 10-27-2004, 07:09 AM
Ya man that works...
The noise is annnoying and would like to be able to start truck or
open door when running without the noise.
Is there a wire that can be identified and cut?
Can the box where the chime comes from be disabled?
Old 10-27-2004, 09:38 AM
drewgibs drewgibs is offline
i just got really pissed one day and took my gerber and ripped out that little plunger that senses if the door was open or not....probably not the most proffesional mod....and now the lights dont come on when i open the driverside door
Old 10-29-2004, 05:33 PM
that1guy that1guy is offline
I got a 95 LS too. What I had to do to disable mine is:
I took the switch out (obviously) and took it apart. Becareful of this. There are parts that will fall out. If I remember right. You should see 3 long metal strips inside the switch assembly. They run along the body. They provide the power from the wires to the pluner and back. I don't remember exactly which one of them, I believe the middle one, needs to be removed from the switch. Then reassmble the switch and put it back in and hook the wires back up. This will allow all the interior lights and everything to work with the exception of the door chime wont annoy the hell out of you. I feel you pain there. I hope this helps. Later man
