Old 10-26-2004, 08:17 AM
becca3733 becca3733 is offline
blower not working
was wondering if anyone knew what could be the problem with my hearter blower. numbers 1-4 stopped working a while back and only number five has been working. now however, number five is no longer working either. turn the knob and nothing happens. do you think it is the blower res. switch or the ignition switch harness. we are going to try and do this on our own to save us a big repair bill from the shop.
Old 10-26-2004, 09:14 AM
joker1s joker1s is offline
Send a message via Yahoo to joker1s
Re: blower not working
I had the same problem on my 97 gtp. I had to change out the blower motor and resister switch. It was fairly cheap and not that hard to do.
Old 10-26-2004, 12:39 PM
BIG-L's Avatar
BIG-L BIG-L is offline
Sounds like you are now having problems with both.When the blower resistor goes,it then puts a strain from the increased voltage on the contacts inside the ignition harness,which in turn causes it to go bad.here is a link to help you with both.
~Larry~
http://www.automotiveforums.com/vbul...6&goto=2287176
ClubGP Member 6530
Since 2001
