Old 10-26-2004, 12:58 AM
97GSTspyder's Avatar
97GSTspyder 97GSTspyder is offline
Send a message via AIM to 97GSTspyder
HKS type0 turbo timer help
I've looked through all the threads and tried VFAQ and all they had was the installation for a 1g....Now...I know where the parking brake wire goes and the speed sensor wire goes....But after looking through the 2G turbo ECU pinouts i can't find the RPM signal wire....Anyone know where this wire would go to from the turbo timer? I can't find it anywhere in the ECU diagram.
Thanks for the help
Old 10-26-2004, 02:16 AM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
Re: HKS type0 turbo timer help
Look at instructions for any other turbo timers on 2g. It's something like the CAS wire, but I've never desired a turbo timer. Already have one with the alarm.
Old 10-26-2004, 12:09 PM
Hpnotiq86's Avatar
Hpnotiq86 Hpnotiq86 is offline
Send a message via Yahoo to Hpnotiq86
What alarm do you have? I want one of those 2-way alarms....
Old 10-26-2004, 02:14 PM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
See if you can find a diagram for the SAFC-II install. I had to tap into the RPM signal wire when I wired my SAFC-II up.
Oh, here it is....
Go to
http://www.prostreetonline.com/pso/p...p?articleid=25
it shows how to install a SAFC-II. It says that it's ECU pin-out #58. (also called engine ignition signal). You will probably have to cross reference this with the ECU pin-out diagram from VFAQ.com. Look in the electrical section. It looks like it is the smallest plug on the ECU (out of 4) second wire from the left on the bottom row (opposite side of the tab you push to remove the plug). You will want to double check this before you go hacking wires, just in case I read it wrong.
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 10-26-2004, 07:17 PM
all right thanks a lot guys
Old 10-26-2004, 11:01 PM
JoeWagon's Avatar
Banned
I have a Compustar 2 way, with Spread Spectrum instead of FM band. 1.25 mile, autostart, turbo timer, alarm, motion sensor, blah blah... cost me about $900. autostart on a 5 speed is difficult.
http://www.compustar.org/products/2WSS.html
Old 10-26-2004, 11:06 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
how does it do autostart on a 5speed? i checked the site but didnt see much
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 10-27-2004, 01:21 AM
JoeWagon's Avatar
Banned
What is checks is that the parking brake is on, and probably that the car isn't moving. What you MUST be sure of is that the car is in neutral. If your car is in first, the starter will JERK the car forward, multiple attemps to start the car.
Viper won't do it because of liability.
In the winter, where you can't use the parking brake in Alaska (because it gets frozen) my car was in neutral with no brake. Just on level ground. STupid idea, huh?
