Old 10-26-2004, 12:33 AM
m249kill m249kill is offline
Send a message via Yahoo to m249kill
Question 1992 chev s-10 blazer, I need help please!
Hello everyone! I have a 1992 chev s-10 blazer with the 4.3 v-6 vortec engine.It has started dieing out on me, I can let it set for an hour or so and it stars back and will drive a little longer then stall again! I thought it was the fuel filter so I changed it today when it stranded me again but that did'nt fix it.I can hear the fuel pump running and pumping. Has anyone else had this problem, if so what caused it? Two friends mentioned two different things, but I want to replace the right one if either of the two mentioned is the problem. They mentioned the module in the distributor and also the fuel pressure regulator! Please let me know something, this is my only means of transportation! Thanks: Sincerely:m249kill
Old 10-26-2004, 12:29 PM
tom3 tom3 is offline
Re: 1992 chev s-10 blazer, I need help please!
Sure sounds like the ignition module heating up and failing. Common symptom. Remove and take to autozone and have them test it a couple times. Cost about 30 bucks to replace.
Old 10-26-2004, 05:36 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
do you have the black & orange vortec plate on the top of you engine?
Old 10-26-2004, 07:11 PM
Yes I do have the vortec plate on top of engine!
Old 10-26-2004, 07:40 PM
BlazerLT's Avatar
AF -Advisor
1.) Are you getting any check engine codes?
2.) Are you experiencing poor fuel economy?
3.) Is your exhaust black sometimes?
4.) Do you smell fuel from the engine compartment sometimes when accelerating?
Old 10-26-2004, 09:49 PM
Blazer/LT answer to your 4 questions is all no! none of those symtoms. no fault codes either! Thanks everyone!
Old 10-26-2004, 09:58 PM
BlazerLT's Avatar
AF -Advisor
Remove the plate on the top of your engine and carefully remove the valve in the top of the plenum and take a flashlight and look inside the engine and look for clean washed places and pools of fuel.
Also, smell for fuel.
Old 10-27-2004, 10:54 AM
Mr.V8 Mr.V8 is offline
Get A V8
Get A V8,
Drop The V6
Old 10-27-2004, 10:55 AM
Get A V8
Old 10-27-2004, 06:38 PM
BlazerLT's Avatar
AF -Advisor
Why did you even post?
