Go Back   Automotive Forums Car Chat > Mazda > MX-3
Old 10-26-2004, 12:04 AM
batmx3man batmx3man is offline
Bolt pattern ???
Does anyone know what the bolt pattern on a 92 GS is?
Old 10-28-2004, 05:48 PM
mx3man's Avatar
mx3man mx3man is offline
Send a message via MSN to mx3man
Re: Bolt pattern ???
4x100, all MX3's have the same bolt pattern.
As for the offset, you need 38, 40 or 42 offset
Old 11-14-2004, 11:33 AM
Vanished Vanished is offline
ok, slightly newbie question...what is offset?
Old 11-14-2004, 01:52 PM
mx3man's Avatar
Zero Offset
The hub mounting surface is even with the centerline of the wheel.
Positive
The hub mounting surface is toward the front or wheel side of the wheel. Positive offset wheels are generally found on front wheel drive cars and newer rear drive cars.
Negative
The hub mounting surface is toward the back or brake side of the wheels centerline. "Deep dish" wheels are typically a negative offset.
found it on google
Old 11-15-2004, 09:13 PM
thanks man
