Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 10-25-2004, 11:25 PM
oztofrdm oztofrdm is offline
buying a GSX
im a RX7 guy, my apex blew and i might have stumbled apon a 1g for $1000 it just needs a bolt on the top of the trans. so i know how to work on just about any car. my question is other then a full tune up what are the first couple of mods to do. how much emmissions can you remove
i have walbro 255 pump, low impedence 550cc injectors(will they work in gsx).
do you need a fcd for higher boost, do they make upgrade chips for the ecu or do you have to go full standalone like a rx7. i am going to put a turboback exhaust, hks bov, a/f and boost gauge to start and what kind of upgrade turbo would i be looking for, i want about 350whp+++ maybe full boost at 3,300rpm
its been a while since i have even seen a piston motor!!! Oh BOY!?!?!!?!
Old 10-25-2004, 11:34 PM
guitarXgeek's Avatar
guitarXgeek guitarXgeek is offline
Send a message via AIM to guitarXgeek
Welcome to the world of DSM's! You'll notice that there is a TON of online help and the entire community is very nice and helpful! So far, it looks like you've got the right idea about how to go about modding the car. MAINTENANCE FIRST! Timing belt, water pump, etc. before you do ANY modding. Check out this website for a good upgrade path! http://www.dsmtuners.com/tuning-guide/1gturbo/ Their forums are also an EXCELLENT source of more technical and advanced information! Have fun and happy boosting!
95 GSX
DSMlink, "50 Trim", and track times coming VERY SOON!
Old 10-26-2004, 12:05 AM
so am i reading that correctly that the stock turbo and smic on a 1g can support 300hp, what size injectors are stock on a 1g are my low imp. 550cc going to work or are they going to collect dust till i can get a bigger turbo
i havent gotten the car yet but I hope in the next few days i will be boosting soon, i was going to get another rx7 but money is tight and all i could afford is a turbo charged allwheel drive mitsu HAHA o wheel i guess ill join the piston bandwagon again
how much hp can me expected from a full 3'' exhaust, an rx will add 2 more psi and about 55rwhp on 3'' exhaust alone
Old 10-26-2004, 02:51 AM
joemathews's Avatar
joemathews joemathews is offline
Re: buying a GSX
Are you serious? I don't know my RX-7s, but that figure seems waaay to high. What gen are we talking about here?
300whp is very difficult to achieve on a 14b. 309whp is the record as far as I know (without nitrous), on a very highly modded car (cams, injectors, pump, management, etc.). 275whp is not an unachievable goal at all, though.
1996 Eagle Talon
Old 10-26-2004, 03:27 AM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
Re: buying a GSX
I don't know what kind of injectors you have. If they are compatible with a DSM, you can install them when you have a device to control fuel, like an S-AFC or DSMlink (which the 1g version is coming out extremely soon if not already).
You may be able to run 12's on a stock 14b, but 350whp and stock SMIC ain't happenin. Who knows how much an exhaust will add.
Fortunately, 16g and 20g turbos are bolton for 1g's. You can get any variation of 16g and have plenty of fun on the street, and if you really felt like 350whp was a number you wanted, you could do that too.
FCD sucks, you don't need it. You can hack the MAS on a 1g to avoid fuel cut for a while, and with an S-AFC you don't need to worry about it since the ECU will see -% compensation for 550's. Stock is 450's.
Try to search before asking all the stuff I know you want to know. There's a member here called something like '10.5secAWDtalon' that hasn' posted in a while, which you can search his posts and find his mod list to run 12's. Cool guy.
Check out the site list in the FAQ sticky, you'll want to check out VFAQ and 1000AAQ. Good luck.
Old 10-26-2004, 04:09 AM
kjewer1 kjewer1 is offline
AF - Advisor
Re: buying a GSX
Exahsut mods are HUGE power increases even on NT Rx7s. Turbos ones even more so! FCDs are commonplace on Rx7s, but never used on DSMs. Its a different style of tuning altogether, mainly because we use MASS air metering, not speed density. Standalones are quite unnecessary. You've got some reading to do! Enjoy
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 10-26-2004, 08:09 AM
Re: Re: buying a GSX
im talking about the 2nd gen, the best gen.
http://www.racingbeat.com/FRmazda2.htm
racing beat quotes by, it dyno proven, its not a direct link but click it, RX7 86-92, under the scroll bar look for hi perf. exhaust, then look for COMPLETE EXHAUST SYSTEM 87-91. kinda wish i didnt blow an apex.(old motor not stupid driving)
im in wilmington and i raced a car that my friend had been telling me about for a while, he didnt even go off the line, i was two car lenghts and i was like shit another NA soon i come to find out that its a 2g 10sec gsx i got bitch slaped to say the least.
Old 10-26-2004, 01:13 PM
gerrrrrrrr i just found out that its not a gsx but a gst and its a talon. the talon part dosent bother me its just the fwd part. i tried looking but has anyone put a gsx drivetrain in there gst and done a write up. or are the parts two different.
is there a difference in the motor, how much power is possible with the fwd with out too much slipping
sorry that fwd is kindof throwing me off but it is only $1000
