Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 10-25-2004, 10:06 PM
DUlrich1227 DUlrich1227 is offline
Send a message via AIM to DUlrich1227
Part #p74186 *carter Fuel Pump
Ok any one use this for a replacment ?
I have narrowed the root of my problems to the fuel pump .. When the Car is up to heat (after driving for @ 20-30 mins) apparently the fuel pump was giving out...('96 JGC @ 124k) not sure why ... seizing up from being to hot...
But heres my ?...
Someone mentioned the above part last week in a post..so i picked it up today...(to bring to mechanc tommorrow) ** he wanted to charge me 400 bucks for one from the dealer.. the above mentioned part is $89 at advanced auto...
In the box is a metal cylander part .. i am assuming this is the motor. and some gaskets and instructions ...
Does anyone know about the above mentioned part?
HERES A LINK :http://www.partsamerica.com/PartDeta...tNumber=P74186
I more or less want to make sure the mechanic doesnt give me a hard time about it not fitting or soemthing..
Old 10-25-2004, 10:53 PM
The_Penguin The_Penguin is offline
Re: Part #p74186 *carter Fuel Pump
Looks like a fuel pump.
I think it lives inside the gas tank, so the gasket is probably for the access plate for the pump and the fuel gage sending unit.
Old 10-25-2004, 11:57 PM
dksob81 dksob81 is offline
Send a message via ICQ to dksob81 Send a message via AIM to dksob81 Send a message via MSN to dksob81 Send a message via Yahoo to dksob81
Yes, the Metal cylinder looking part is the Fuel Pump.
Old 10-26-2004, 12:26 AM
Re: Re: Part #p74186 *carter Fuel Pump
thanks...
been meaning to get back to you ... looks like it is the fuel pump..
when it got hot it was failing ...
I am hoping . !
Old 10-26-2004, 12:51 AM
I have one more question for ya, does ur problem exist when u have a full tank or only on low tank?
Old 10-26-2004, 02:13 AM
either...
no matter where the gauge was...
and like i said it's only when the enigne has been running ...
Old 10-26-2004, 10:25 AM
OK, I was wondering cuz it is very common for a fuel pump to go bad and get hott and shut down, but I have only seen this when it was below 1/2 tank or so.
Old 10-26-2004, 11:17 AM
Now that i think about it .. it may have ben doing something similar when the tank would fall to 1/4 for a while than when i filled it up it would go away..but for the past 2 weeks it just got worse..enven whe ntank was full
so it was probably going ?
Old 10-26-2004, 11:21 AM
yea I would say so. it has prolly just gotten worse b/c of it getting hott when the tank was low just caused it to get worse and now it is getting hot no matter where the fuel level is at.
Old 10-26-2004, 04:55 PM
Dale Aeppli Dale Aeppli is offline
But heres my ?...
HI, ITS A FUEL PUMP . ITS FOR A 97 CHEROKEE SPORT WITH 4.0 I USED THIS FUEL PUMP WHEN I CHANGED MINE THIS NUMBER IS FOR A 97 4.0 IF YOURS IS A 96 ORDER A FUEL PUMP FOR A 96. IT COULD BE THE SAME NUMBER I DON'T KNOW . ASK FOR CARTER FUEL PUMP FOR 96 CHEROKEE OR WHAT EVER MODEL MAKE AND ENGINE YOU HAVE. CHECK TO SEE IF THIS IS THE NUMBER FOR YOUR JEEP. YEAR MAKE AND ENGINE DALE [email protected]
Old 10-26-2004, 10:41 PM
well the part fit ! No problem truck running good so far..
havnt had it really out yet...
still having the wcky Oil pressure thing .. gotta felling a wire matybe crossed somewhere..
at idle it goes up to say 75 than if i hit the gas it will go down to the 40 mark ...
any thoughts ?
Old 12-01-2004, 04:42 PM
dogette dogette is offline
any thoughts ?
oil pressure sending unit! about $24.00
Old 12-01-2004, 09:07 PM
jeep guy jeep guy is offline
i tried to find this part that cost $90 that Dale mentioned, but when looking for a 96 jgc fuel pump at advance auto it displayed just the whole assembly for purchase. i found this part but it was for a 97 jgc. i wasn't sure if it fit the 96 assembly. looks like you lucked out!! i wish i had seen this thread earlier today. oh well, it works now!
