Go Back   Automotive Forums Car Chat > Pontiac > Montana/Montana SV6
Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 10-25-2004, 10:31 PM
lazerclan lazerclan is offline
2000 Montana Check CD Error
Hi, we have a problem with the cd stereo. After jump starting the van due to run down battery it seemed to do something to our stereo, the radio works okay but every few minutes it "check cd" You can hear it running continously even without a key in. Is there anyway to reset this? Any advice would be greatly appreciated. Thanks.
Old 11-30-2004, 12:03 AM
206 206 is offline
Mine dose the same thing my dealers radio guy says it the release mechanism control in the player needs fixed, $250 to swap mine for one that works
I was hoping it could be reset also
Old 03-13-2005, 12:21 AM
daveycarpet daveycarpet is offline
Re: 2000 Montana Check CD Error
Hi there:......Our CD player did the same thing with the similar noise. We left it for about a day and it fixed itself. We did clean the laser in the Cd.
Davey Carpet
Old 01-30-2007, 05:06 PM
b_dean b_dean is offline
You have to unplug the wire to the CD Player in the back. It will reset itself and you will be good to go. Take the console off, pop out the 3 screws that hold the stereo in place, slide it out and pull the plug out. Pop it all back together and you are good to go!
I had the same problem and I was gonna buy a new stereo. Glad I didnt.
Old 06-20-2007, 01:03 PM
kaisir42 kaisir42 is offline
Had the same problem with my 2000 Montana after my wife killed the battery. Not entirely sure what she did, but that battery was completely drained. After jumpstarting, the CHECK CD message kept coming up, accompanied by repeated noise from the CD player. Sounded like the player was attempting to eject a CD that wasn't there.
Located the 10amp radio fuse in the fusebox under the hood. Removed and replaced. problem solved
Old 06-20-2007, 03:30 PM
'97ventureowner's Avatar
'97ventureowner '97ventureowner is offline
Please check the dates before posting There will not be a third time this thread is resurrected.
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people.
If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno
" A Good Thing To Know"
Closed Thread
