Old 10-25-2004, 09:07 PM
eli323232 eli323232 is offline
Is it possible?
I have a 75 shot of nitrous on my 93 lx. I want to add a supercharger in the future. My question is would it be possible to retain my nos and add it on top of the s/c or would that make my engine go kaput.
Old 10-25-2004, 09:57 PM
ModifiedCars04's Avatar
ModifiedCars04 ModifiedCars04 is offline
Anything ig possible with the right setup
" A old wise man once told me something, I simply replied I have a bad memory, that, david is way I can't tell you what the old wise man said "
Old 10-25-2004, 10:25 PM
StangNut86 StangNut86 is offline
Send a message via AIM to StangNut86 Send a message via Yahoo to StangNut86
keep the boost levels down and you should be alright. your stock bottom end will only take so much horsepower (usually 500) before you send it through the pan. personally i wouldn't risk it, but that's your choice.
-Andy
'89 Mustang 5.0 - How fast? i'll know this weekend.
'86 Mustang LX - Shortblock is built, now for the rest of it.
"Put the subject before the verb, hmm? Fail this class, you will."
-Yoda teaches english class.
Old 10-26-2004, 01:09 AM
motor_head_429 motor_head_429 is offline
How much boost do you plan on running?
Old 10-26-2004, 12:27 PM
Re: Is it possible?
I was just planning on running whatever boost the kit from vortech comes with, I think it is 8-10.
Old 10-26-2004, 12:52 PM
Mendari Mendari is offline
Re: Re: Is it possible?
You could also re-route the nitrous line to cool at the intake charge instead of directly at the port. You won't make as much power, but you also won't have to worry about breaking through the main caps either.
Old 10-26-2004, 04:44 PM
I think if you keep the boost at 8 pounds, you should have no problem running a 75 shot. You could also lower it to 50 just to be sure.
Old 10-27-2004, 02:23 PM
Re: Is it possible?
Thanks guys
Old 11-01-2004, 11:28 AM
Korbin Korbin is offline
Re: Is it possible?
Hold up, Eli. Your car was the first year of the hypereutectic pistons. They will not take that abuse. I have replaced peoples motors that ran 12psi others running a 175 shot. Those pistons have a nasty tendency to break apart at that cylinder pressure level and won't take much detonation at all. Pick one power adder and be moderate. Or put in some forged pistons and make sure you have enough fuel flow rate and pressure and be careful with your timing.
Old 11-01-2004, 01:02 PM
Re: Is it possible?
What is a hypereutiectic piston? how is different from other year model's pistons?
Old 11-02-2004, 02:12 AM
Re: Is it possible?
Hypereutectic pistons are a step above cast pistons. They have silicon added for extra strength, but they're not very desirable for high cylinder pressures and shatter.
Old 11-02-2004, 02:14 AM
Re: Is it possible?
Ford used forged pistons in Mustangs from 86 to 92 and then went to Hypereutectics from 93 on to save money. They're not that bad on mild applications.
Old 11-03-2004, 07:28 PM
Re: Is it possible?
so would the supercharger alone be too much for my pistons?
Old 11-07-2004, 09:58 PM
Re: Is it possible?
Not at all, just keep the boost reasonable and watch your timing and make sure you have enough fuel. I've seen plenty of people running 10 psi on stock internals.
Old 11-08-2004, 07:23 PM
Re: Is it possible?
thanks for your help
