Go Back   Automotive Forums Car Chat > Oldsmobile > Bravada
Old 10-25-2004, 09:04 PM
aharbormoon aharbormoon is offline
Question Newbie Here- with a heater blower problem
Hi all, I just found this forum.
I wonder if any of you might know what the most likely reason that the heater blower motor in a '97 Bravada sometimes will not run? There seems to be no true pattern to when it fails to start up. But it does seem to be the most frequent when it is cold out, but also has refused to run at times when I needed the a/c too. If I turn on the blower and it doesn't run, nothing I do will get it running. It may start to work the next time I drive the car though, be it 6 hours or 2 days later. It never quits if it starts and remains turned on. I'm wondering if it has something to do with some intermittent temperature sensor trouble?
It really sux when it's frosty out in the morning!!
I hope I can contribute to this forum at times.
Thanks for all thoughts and expertise you all may offer!
Harbor Moon
Old 10-26-2004, 03:56 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: Newbie Here- with a heater blower problem
Sounds like the blower motor is worn out. Sometimes you hear about a blower motor relay as a possible problem but mine are the motors themselves.
Old 10-31-2004, 01:07 AM
Re: Re: Newbie Here- with a heater blower problem
Thanks, I hope it's not the motor, it's work to get that thing out! I'm going to take a look at the relay and connections first as it sure acts like an intermitant electrical connection/contact problem. If no luck there then maybe the motor has a flat spot I'll have to change the motor then.
Old 12-15-2004, 02:09 PM
kukukbird kukukbird is offline
my 96 is doing the same. did you change the motor and fix it?
Old 12-16-2004, 07:24 AM
sboblett sboblett is offline
My 97 Bravada had the same problem and it was the electrical connector that plugs into the firewall on the passenger side of the vehicle. It is a two pronged rubber connector and my problem was also intermittent and worse during cold weather. Turn the fan switch on and jiggle this connector, you can hear the fan come on. You might try cleaning it. If you need more info let me know
Old 12-16-2004, 01:01 PM
thank you!!!
I also noticed that if I wiggle the plug - The fan will come on. I thought that the fan had a short inside but I will try to clean the plug and see what happens.
Old 04-08-2005, 02:34 PM
johnbell johnbell is offline
Send a message via Yahoo to johnbell
Harbor Moon
My Dad has the same problem with his 94 in Alaska. Tell me that don't suck. A couple days ago it did it to me, wouldnt come on untill I after I hit the brakes (wet) and abruptley stopped. Then suddenly came back on.
