Old 10-25-2004, 08:52 PM
Bikeman1010 Bikeman1010 is offline
Unhappy Amp Problems
I was hooked up my compasitor, let it charge to 14 volts like i was suppose to. Turned on the deck to vol. 3 out of 35. The amp turned on and worked. But the second i turned it up any more it turned off. i thought it was because the compasitor wasnt charged enough. still didnt work. after getting really pissed off i unhooked the compasitor and wired back up the amp. But for some reason the amp wont turn on. I even got out the volt meter and i am getting power to the amp. i have no fuses blown and the amp wasnt hot at all. i even rechececked the remot switch all the was to the deck and it was fine. if anyone knows what seems to be wrong please write back
Old 10-25-2004, 09:42 PM
Haibane's Avatar
Haibane Haibane is offline
Send a message via AIM to Haibane
Re: Amp Problems
Try a larger remote wire... Where are you connecting the remote wire?
P.S. what is a compasitor? does it have compassion on your system for you?
www.cloudcity.deviantart.com
Old 10-26-2004, 09:34 AM
TFFantasy44 TFFantasy44 is offline
Re: Amp Problems
Hmm. If you can, take the cover off your amp and check to make sure its not blown, or if you have another amp, hook it up. Make sure the ground is okay too.
1996 Cavalier 2.2
[size=-1]
Audio Set-up
--Currently have--
NINe.1 Amp
eD 15A.22 Sub
Alpine 9855 Headunit
Old 10-26-2004, 04:59 PM
Re: Re: Amp Problems
I took the amp cover off and checked everything. It all seemed to be fine. i even smelt around for that burning smell and still no sign of it being blown. I checked the ground too and that was fine. i am officially confused on what it could be. i dont think u can burn out an amp from to little power, can you?
Old 10-26-2004, 05:03 PM
A compasitor is like another battery. when the bass hits it uses up alot of electricity. insted of the amp taking bursts of energy from the battery and the alternator it takes it from the compasitor. the compisator just draws constant energy insted of bursts. this relives stress on your compasitor and stops dimming head lights etc.
Old 10-26-2004, 05:24 PM
Abell255's Avatar
Abell255 Abell255 is offline
Send a message via AIM to Abell255
...wow hai, oh, a capacitor?
-=Alpine 9855=-
-=ID MAX 12" d2=-
-=Elemental Designs Nine.1=-
-=Sealed in 1.5 cubes=-
-=CDT EF-61s=- ( coming soon )
-=Profile CA400=- ( coming soon )
Old 10-26-2004, 06:08 PM
Haibane's Avatar
Re: Re: Re: Amp Problems
Old 10-28-2004, 12:24 AM
torin2 torin2 is offline
Re: Amp Problems
Wow
