Go Back   Automotive Forums Car Chat > Volkswagen > Passat
Old 10-25-2004, 07:58 PM
96ssat 96ssat is offline
transmission trouble
1996 Passat GLX
recently my transmission has been very finicky. occasionally, It has trouble going into first. If I am coming into a stop with my cluth in, and attempt to put it into first going faster than a few mphs, gears grind. Likewise, if i am at a stop in neutral, and attempt to put into first, it occasionally does not want to go in. Either way it goes into gear fine if i am moving slowly, get gears moving.
anybody have any thoughts/insight
synchro wear? new trans? i hope not the latter
Old 10-26-2004, 09:30 AM
boschmann boschmann is offline
Re: transmission trouble
Are you sure it has the correct gear oil & is full? VW reccomended SAE 80W-90 (at least GL-4) oil or you could try 75W-90 Synthetic. VW also says it never needs changing, but I would every 90K miles.
Old 12-17-2004, 11:05 AM
formerg60 formerg60 is offline
I believe there is a tech bulletin which states that if the car upshifts quickly, leaving you little power on tap the Transmission Control Module(TCM) needs to be replaced. For the time being I get around this by using the tiptronic(pseudo-manual) mode.
