Old 10-25-2004, 07:12 PM
2doorblazer 2doorblazer is offline
Unhappy 2002 Blazer front suspension
I have a 2002 2 door blazer LS. The front end seems to hit bumps harder than normal(road bumps,not off road). Example: Driving over train tracks causes the front end to shake pretty badly. I've been to the dealership and as usual everything is okay by them. Time to go to the experts.......anybody have any ideas? This truck only has 24,000 miles on it and is a highway commuter.
Old 10-25-2004, 07:23 PM
Mikado14 Mikado14 is offline
Re: 2002 Blazer front suspension
Original tires?
Old 10-25-2004, 07:33 PM
Original factory aluminum rims. Not original rubber though. Currently running General Ameritrack SUV 235/75.
Old 10-25-2004, 08:00 PM
This may sound a little crazy but, if everything checks out fine it could be the tires. You may have them overinflated or it could be the tread giving you a firmer ride.
Old 10-25-2004, 08:20 PM
I keep the tires at 32 psi. The tires that came with it when I bought it were no name with crappy tread and they road the same as these. This front end shaking over bumps is borderline violent. Any other ideas?
Old 10-25-2004, 08:38 PM
The problem with a forum is that it is completely by language and the sense are not there.
When you say "violent" it concerns me.
Is it strictly that the front end sounds like you hit a pothole?
Can you feel it in the steering wheel?
Does it shimmy when you say "hit the railroad tracks"?
Do you feel anything in the floorboards?
Does the frontend bounce excessively?
Do you feel like the vehicle's rear wants to go sideways?
If all the steering components and the suspension components have been checked, and I will assume by someone reputable and knowledgeable, we have to get a footing. Has an alignment been done?
We could be looking at upper and/or lower A arm bushings, or, body mounts if it looks as if the front end itself is shaking, or, it could be rear tortion mounts.
Are there any driveability problems other than the railroad track bumps?
Old 10-25-2004, 08:47 PM
Front end sounds like I hit a pothole.
Can feel it in the steering wheel.
Minor shimmy felt hitting railroad tracks.
Do not feel anything in floorboards.
Front end does not bounce abnormally.
Rear end.......not so sure.Will check.
Yes an alignment has been done by the local Chevrolet dealer.
Other driveability problems: Slight vibration at 65, goes away at 70. What do think it could be?
Old 10-26-2004, 09:00 AM
powering powering is offline
I suggest you do the hinge bolt retainer washer fix posted below. Mine was doing the same and I know you will be skeptical but it is such an easy and cheap fix to try. Mine also had a vibration around 65 mph.
Try it and if it works post that it does so others know.
Old 10-26-2004, 09:43 AM
Re: Re: 2002 Blazer front suspension
One at a time:
Front end sounds like I hit a pothole - This on first glance would have me looking for loose steering and suspension components.
Can feel it in the steering wheel & Minor shimmy felt hitting railroad tracks - If you can feel a shimmy on bumps, I would have the alignment done by someone who specializes in it and it would be a four wheel alignment.
Slight vibration at 65, goes away at 70. - Again, a front end alignment or possible cord seperation on a tire.
You may have a combination of problems. The loud noise upon hitting a bump could be the rear tortion mounts coupled with a much needed alignment. My recommendation would be the front end alignment (four wheel) and have them check the suspension and those rear tortion arm mounts.
Old 10-26-2004, 05:27 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
2doorblazer,
Does it clunk or pop when you hit a pothole or go over the tracks?
Old 10-26-2004, 07:17 PM
No clunk or popping heard. Already did that washer quick fix. Thanks. If I needed an alignment wouldn't my Blazer tend to pull one way or the other? As far as suspension componets go I'm a little out of my league. I've tugged on everything but nothing seems out of the ordinary. What exactly do the torsion arms do? Seems like I'm going back to the dealer to take someone for a test ride. Appreciate every one's input.
Old 10-26-2004, 07:42 PM
BlazerLT's Avatar
AF -Advisor
don't go to a dealer, go to a respected local mechanic in your area. It will be cheaper.
Have your tie rods and idler and pitman arms inspected for being loose.
Also, do you have some play in your steering wheel?
Old 10-26-2004, 07:48 PM
There is some play in the steering wheel above and beyond the usual. Seems like there is a lot to check when it comes to suspension. Anything else that should be looked for?
Old 10-26-2004, 07:51 PM
BlazerLT's Avatar
AF -Advisor
Just tightness of the whole setup.
jack up your passenger side front and wiggle the tire right and left and check for play in your tie rods and you pitman and idler arms.
Chances that is your problem.
Also, you are telling me that you have no clunking, knocking or anything when you hit bumps? It is just loose right?
Old 10-26-2004, 07:57 PM
I have jacked up the truck and wiggled the tires. Nothing out of the ordinary when I did that. When I do hit the right style of bump(dip not raised) the front end shakes. I can feel it in the steering wheel and I do sometimes hear a clunking noise if the bumps are more of a washboard style.
