Go Back   Automotive Forums Car Chat > Subaru > Impreza/9-2x/Outback Sport
Old 10-25-2004, 06:56 PM
00_impreza 00_impreza is offline
Send a message via AIM to 00_impreza Send a message via Yahoo to 00_impreza
brake noises
i have an all stock 2000 impreza, and the brakes seem to be making a non stop squealing all the time, but it STOPS when i do brake or go through any kind of curve.
brakes and rotors were replaced 5 months ago. it stopped for awhile but started again not long after they were replaced and still goin. any kind of ideas?
Old 10-26-2004, 05:26 AM
ragnarok720 ragnarok720 is offline
Re: brake noises
warped your rotors or your calipers are closing up just enough so the pad barely touches.
Old 10-26-2004, 09:43 AM
kfoote kfoote is offline
Re: brake noises
What kind of brake pads did you put in? This is often caused by the brake pad itself brushing against the caliper. It goes away when you hit the brakes because it's not vibrating on and off against the rotors, which can cause the squealing.
2004 Subaru Impreza WRX STI (daily driver)
1999 Mazda Miata (track car, slow, but finished the SCCA Runoffs)
1987 Porsche 944 (being rebuilt)
Old 10-26-2004, 12:19 PM
Re: Re: brake noises
eep....well the steering does shake under medium braking...
what kind of stuff causes rotors to warp? cant say i remember any time where i had to slam the brakes.
Old 10-26-2004, 02:53 PM
SabreKhan's Avatar
SabreKhan SabreKhan is offline
The middle pedal is bad
Re: brake noises
Holding the brakes after heating them will also cause warping. For example, if you drove it hard for a few minutes around some turns and twistys, then stopped at a red light with your foot holding the brake down for a while. There are lots of ways to warp the brakes, and some of them are really easy to do.
Look at the teeny picture of my car!
2004 Impreza WRX (SCCA DS 519)
2000 Saturn SL
Old 10-26-2004, 06:18 PM
Re: brake noises
mashing on the brakes and hitting a puddle of water can cause it. anything that would cool your brakes down can cause it. check your rotors to see if they have heat spots as well, they'll look like spots on the rotors.
