Go Back   Automotive Forums Car Chat > Isuzu > Amigo
Old 10-25-2004, 04:04 PM
mickeyk7 mickeyk7 is offline
1990 amigo fuel pump relay problem???
Car starts and then stalls, but if I have someone "tap" the relay while starting it stays running. I have changed the relay. Could it be the fuel pump?? Thanks
Old 10-26-2004, 10:12 PM
2eyefishclaw's Avatar
2eyefishclaw 2eyefishclaw is offline
Send a message via AIM to 2eyefishclaw Send a message via Yahoo to 2eyefishclaw
Re: 1990 amigo fuel pump relay problem???
if tapping on the relay helps I cant see where the fuel pump would be the problem sound more like weak current/low voltage to relay or high resistance in the ground circuit
Old 10-27-2004, 10:18 AM
Re: Re: 1990 amigo fuel pump relay problem???
I'm puting in a new alternator today, I hope this is the anwser...
Old 10-29-2004, 03:24 AM
barteldt barteldt is offline
Send a message via AIM to barteldt Send a message via Yahoo to barteldt
wow i had a similar experience in my 94 2.6 l it died tryed to start and it would start and immediately die had it towed to a shop and it started right up i pulled the relay at home and it does exactly the same thing i did put some new battery cable connectors on earlier so im wondering if this is related but it did turn over and partially start just wouldnt run
Old 10-29-2004, 01:06 PM
Fixed!!!!
It was the alternator. She's running sweet!
