Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 10-25-2004, 02:33 PM
mrx7255 mrx7255 is offline
Send a message via AIM to mrx7255
SR20DET S13 Problem!!!!!!!!!!!!!!!
My friend has a SR20DET S13 Red Top and he's been having probelms with it. When he starts to drive the car it starts to buck and the exhaust is really loud. The first thing we did was check for leaks but there are none. Then we started adjusting the TPS (thorttle position sensor) and it worked. The car ran perfect for about a half hour or so. After that it started doing it again and now with a new TPS and clip for it...it still doesn't work. We look at my SR20DET and ajusted it to that but no good. Now I don't think it is TPS.....
Any ideas????????????????/
Old 10-25-2004, 02:41 PM
SHO411's Avatar
SHO411 SHO411 is offline
Re: SR20DET S13 Problem!!!!!!!!!!!!!!!
buck, and ehaust is loud, thats all??????
the discription is vague, but check you fuel, it might be sending more fuel in than needed. not realy sure, is there a spike or drop in rpm, is the the rpm needle moving up and down, is the motor shaking? and does it do it only when he is taking off or even when idling?
Ain't this the pretiest motor or what?
Fines are the fee you pay for the privilege of driving as fast as you want
Old 10-25-2004, 02:52 PM
Re: Re: SR20DET S13 Problem!!!!!!!!!!!!!!!
We checked all the Injectors and test them with a multimeter and the fuel pump.
The car feels like there is a lot of stress being on it and it can't go fast. Around 2500rpm the car won't stop buckin but it passes as the rpm's go up. Thats why I thought it was like a dead spot in the TPS but I don't. Also after you go go past like 5,000 rpm it picks up speed fast.
Thats all that happens with the car.
Old 10-25-2004, 03:03 PM
SHO411's Avatar
You might want to check you distributor, and ignition system, sounds like a spark problem, not 100%, I ain't that good at diagnostics.
Old 10-25-2004, 05:29 PM
R.W.240's Avatar
R.W.240 R.W.240 is offline
Banned
Yea that be it y0!!!11doh!!!11
have you checked the MAF and its wiring?
Old 10-25-2004, 06:29 PM
His SR20DET doesn't have a distributor and the cam angle sensor was tested and so was the MAF.
Old 10-27-2004, 12:50 PM
SHO411's Avatar
Every freaking car has a distributer, whether it is mechanical or electronic, under electronic you could have the single coil packs over each cylinder, or the single unit that all plug into. You could also have like the pontiacs dist which uses a coilpack for every two cylinders. BOTTOM LINE, every car has some form of distributer.
Old 10-27-2004, 01:52 PM
InFuZiOn InFuZiOn is offline
Send a message via ICQ to InFuZiOn Send a message via AIM to InFuZiOn
Unless he somehow did all the wiring straight from the battery haha. Your right man. EVERY car has a distributor.
Old 10-27-2004, 03:09 PM
AWDSR20 AWDSR20 is offline
Send a message via AIM to AWDSR20 Send a message via MSN to AWDSR20
so is it fixed? what happened?
"A good driver is measured not by his lap times, but by the amount of time he spend trying to make sense of his car"
E.K.
Old 10-27-2004, 03:16 PM
We can't figure it out so he's probably going to send the car to paisley automotive they can fix the car no problem they are just alittle expensive.
Thanks though
Old 10-27-2004, 03:27 PM
good luck keep us posted!!
E.K.
Old 10-27-2004, 05:16 PM
SR20DETpower SR20DETpower is offline
Banned
Send a message via AIM to SR20DETpower
DIS
Distributorless Ignition System.........
also back on topic... put your MAF meter onto his car and see if that helps.. it sounds like that is the problem... same sorta thing happened when my brothers Maxima's MAF got wet. I am about 90% certain the problem is electrical and involves telling the computer how to run the engine, if its not the MAF look for other sensors, wires, and the actual computer for problems...
let us know what the problem is when u find it
Old 10-28-2004, 03:57 PM
mynismo mynismo is offline
yada yada yada
Send a message via AIM to mynismo
ahhh.......... no. sr20's are distributorless and have coilpacks and a crank angle sensor.
go to www.freshalloy.com advanced section, people are more knowledgable there.
if you said that you fooled around with the tps and it worked, then it didn't... sounds like its your tps. just try to find another one and plop it on. other than that it might be your timing.
438whp / 373tq - 11.9 @ 126
Old 10-28-2004, 04:52 PM
driftsilvia driftsilvia is offline
dude i have nothing to help but how does your boddy have a s13, and is it legal and how did he get it legal
Old 10-28-2004, 04:56 PM
R.W.240's Avatar
Banned
what a Tool
I was gonna put one of my witty comments right there but I decided this was more fitting
