Go Back   Automotive Forums Car Chat > Mazda > RX-7
Old 10-25-2004, 12:58 PM
fcdriver fcdriver is offline
Got boost?
Well hopefully in a week or so I will.
I just bought a t2 longblock with complete ecu and wiring harness, intercooler and piping(top mount), everything I need for the swap minus the t2 trans.
I'm going to pick the engine up tomorow and if I can manage to get it to turn over I should be boosting within the week.
Just thought I'd share my new toy with every other rotor head on here.
Future plans arn't in this order but: fuel cut defender, boost controler, 720 secondarys, bigger downpipe and full exhuast (rb more then likely), some sort of fuel monitor (I'm not totaly set on which to get), fmic, and upgrading from the stock turbo ( unsure which I will choose here also).
Hopefully all this can be installed before next spring so I won't have to worry about driving the car and adding things as I go, because it's going to rest for the winter so it stays nice and shiney.
Old 10-27-2004, 02:48 PM
RedFC3S's Avatar
RedFC3S RedFC3S is offline
Re: Got boost?
sounds like a good project, good luck
If your gonna go FMIC and bigger turbo, you might want to consider getting some bigger secondarys, bigger than the 720's
1990 RX-7 Turbo II, Streetport, 62-1 Ball Bearing Turbo, FMIC, R.E. Amemiya exhaust, Haltech E6K, GReddy gauges, Apex-i AVC-R, and much much more
Under a complete Time Attack/Drift makeover
Old 10-28-2004, 09:09 PM
Re: Got boost?
Thanks, I really haven't got the enitre parts list fixed out just yet because I'm having to add things as I go along, ex. rebuilt motor this one is blown, it looks to be an apex seal but I haven't torn it down completly just the intake and exhaust manifolds and theres peices of what looks to be apex seals in the turbo manifold and the rear rotar housing.
One question I have is should I go for a large street port, full bridge or half bridge for a high 200 to low 300 hp aplication?
Old 10-29-2004, 01:20 AM
Soyo's Avatar
Soyo Soyo is offline
Send a message via AIM to Soyo
Re: Got boost?
if its a street car you shouldn't go over half bridge, and street would be the most reliable
a street port should be sufficient for what you're wanting though
1989 RX-7 TII --- Just got rebuilt and street ported
RB 3" dual exhaust, BNR stage 1 modified factory turbo, FCD, S-AFC II,
720cc secondaries, Aftermarket Turbo inlet duct w/K&N, Hawk HP+ pads
HKS Blow-Off Valve, Stainless brake and clutch lines
Old 10-29-2004, 12:36 PM
D3rELiC's Avatar
D3rELiC D3rELiC is offline
Re: Got boost?
you should get a full standalone rather than a fuel monitor, and dont run over 9-10 psi without fuel management.
you should not spend money on a rb exhaust go 3'' with a good muffler/dp and it will cost you less.
Old 10-30-2004, 05:08 AM
Re: Got boost?
Ok, thanks I was planning on only running around 12 psi so I guess I'll go with a haltech or is there another better standalone?
It is a street car but emisions isn't really an issue here and as far as idling goes I can stand an idle at around 1,500-2,000 rpms without worry ( mpg isn't really an issue either since I don't care how much gas I pour into the tank as long as it gets me where I want however fast I want).
Thanks for the feedback I'll try to keep a tab on what all I do and how much it runs me.
Old 10-30-2004, 06:55 AM
Soyo's Avatar
Re: Got boost?
buy a racing beat exhaust, I don't know why anyone would tell you not to... it is obviously the best exhaust out there and no custom mock-up job at your local muffler shop is gonna match up to it. no offense, I just totally disagree
oh and your idle is too high man, you should idle around 750 and no higher than like 1200
Old 10-31-2004, 04:14 AM
Re: Got boost?
Yeah I was expecting it to idle around 750 like it does now but I've read that a bridge or pp idles higher but I can't remember if they both have a higher idle or just one.
If you can't tell this will be my first "high performance" rotary build aside from the standard header back exhaust and minor intake mods.
I'm still researching on what all I need to go through inorder to keep it as reliable as possible.
Old 10-31-2004, 07:46 PM
RedFC3S's Avatar
Re: Got boost?
bridgeport wont last long at all. When my motor pops, im going full bridge, since It's only a weekend car now. Just stick with a streetport
Old 10-31-2004, 08:42 PM
Re: Got boost?
Ok will do. Any other advice as far as reliable performance products, ei. manufacturers (who makes the best that last the longest)?
Old 11-01-2004, 02:26 PM
RedFC3S's Avatar
Re: Re: Got boost?
oh, and just stick with a koyo radiator, its cheap, and its a must
Old 11-01-2004, 08:15 PM
drftk1d's Avatar
drftk1d drftk1d is offline
boost in, apex seals out
Send a message via AIM to drftk1d
Re: Got boost?
Fuck the stock ecu, save money in the long run, find a haltech.
RX-7 TII
Old 11-02-2004, 11:23 AM
D3rELiC's Avatar
Re: Got boost?
dont forget to find someone who tune them nearby.
Old 11-02-2004, 10:13 PM
Re: Got boost?
Yeah, I've got a local tuning shop about 3 mins away that had moved from the same town that I live in to the next one over. As far as setting everything up and getting a pretune (get it running) I'm pretty sure that I can get everything running right and after I get it on the dyno I'll probably be the one tunning it the way I want it because I want it to run a little rich, not to rich but enough to keep it from leaning its self out at higher rpms.
I've never tuned a standalone but I have tuned several carb engines and I know theres a big differance between the two but I think I can do it with a little help from the tuners there.
