Old 10-25-2004, 12:22 PM
seham123 seham123 is offline
1998 Taurus Heater Problems
Hoping someone out there can help me! I saw the comments about the heater core, but I don't think that is my problem. Heater core has never leaked, car has never ran hot...heater core was flushed and thermostat has been changed out. Could the problem of "NO" heat have something to do with the thermostat control on the front of the a/c-heater/radio controls?
Old 10-25-2004, 07:30 PM
chiefifd chiefifd is offline
Re: 1998 Taurus Heater Problems
I had a similar problem and a Heater Core Flush and system flush by my Ford Dealer did help a bit but didn't get my heat coming from the vents like I thought. The highest Air temp I measured was about 140 % from the air vents. About a month ago I checked the vent air temp again and it was still about 140 % I wanted to flush the system again to see if I could get the air temp up a bit higher. I attempted to remove the heater hoses from the heater core and found the steel lines that run up the fire wall to be very rusty and broke as they were almost rusted through. I flushed the heater core and system myself and replaced the steel lines that run up the fire wall with Gates heater hose and Gates elbows to resemble the original steel heater lines. I put every thing together and gave it a try. I measured my vent air temp after going for a short ride and was very suprised to find the vent air temp was up to 173 % WOW!!!!!! Maybe just maybe it has something to do with the steel lines, maybe they are rusting from the inside and creating some resistance and there for the hot coolant is bypassing the heater core. Please let me know if you try this and if it works. The cost of about 4 feet of heater hose a box of clamps and the gates elbows and straight connectors was about 20$..........hope this works ..it has for me so far. Maybe all the rust were all experencing in the coolant system is from these steel lines.
The Following User Says Thank You to chiefifd For This Useful Post:
taurusRus (08-21-2012)
Old 10-27-2004, 07:52 AM
jimh123 jimh123 is offline
Re: Re: 1998 Taurus Heater Problems
I'm having the same problem, flushed core through those
steel lines, water went through nice, also replace my thermostat,
added fluid, it's warm but not hot air, turn fan on higher or at idle
goes cold again
my temp runs at about 1/3 to 1/2, engie really never gets hot
It almost like there is a bypass valve or someting allowing
fluid to pass even though the thermostat is closed
Old 10-27-2004, 05:55 PM
mwt mwt is offline
None of you guys said what year of car you have.
Anyway I had a 94 that had the same problem.
If both sides of the lines going and coming from the heater core are hot
it is most likely the blend door actuator.
I fixed it myself and if I had to do it over again I would pay someone to do it.
Mike
Old 10-27-2004, 06:31 PM
My Taurus is a 1999....... By the way how warm or hot is the air coming out of your heater vents? Mine is about 160 to 170 depending on the fan speed......Thanks,....ed
Old 10-27-2004, 09:36 PM
tymoto tymoto is offline
Heater blows cold
Same problem on my 99 the heater blows cold air.
Must be a relay somewhere.
Any help/advice would be appreciated
Old 10-28-2004, 07:48 AM
It's warm when the rpms are at 2000 or higher on the highway.
turn fan on high and get cool, at idel blow cold no matter
what the fan is set to
No sure about the temps
Old 10-28-2004, 07:49 AM
One side was hot, the other very warm
I have a 98.
where is that valve you are talking about, is it in the 98's
Old 10-28-2004, 05:32 PM
Found a simple fix!
In the engine compartment take the 2 hoses off the heater core where they go into the firewall and flush it out with a garden hose.
It works!!
Old 12-18-2006, 09:56 AM
lmorgan3d lmorgan3d is offline
Problem was very little heat. Checking the heater core inlet and outlet temps by hand, the inlet was hot, the outlet was luke warm.
I used the garden host to back, and then forward flushed the heater core several times at the firewall and now the cabin heat is back to normal. Typically 140 to 150 deg at the dash registers. Amazing the difference! The fix worked, thanks to all!
..Lynn..
Old 12-18-2006, 12:58 PM
medicmandan medicmandan is offline
My problem ended up being a combination of crap in the heater core and a water pump with almost nothing left of the blades. Flushed the core and replaced the pump, I have great heat now. When it warms up a bit I'll flush the core again just to make sure I got it all out.
Old 12-19-2006, 09:33 AM
dddcccmack dddcccmack is offline
Went to Ford today, found that if you ask for a pri 1999 water pump you will be given a 2000. There have been 3 service bullitins with 3 upgardes to the pump and bypass hose. The diffeance . . . my 97 pump has, by design, bent blades only, the 2000 pump has, along with bent blades, a round disk attach to the blades (something like a large washer) which I assume will make the pump a little more effective. Also the bypass hose is differant . . the hose is shorter and positioned higher up . . not sure why! I see other saying (same with me) if I rev the eng Ill get warmer air . . but I also notice If im going up hill I get hot, if im going down i get cold (both up and down under acceleration/hi rev) my conclution is gravity vis bypass hose highth might be why the new hose was changed. I have a clean core and a good pump (not the new one)but im freezing . . . it got down to +30 last night! Also i might add when i flushed the core i filed it with a full strangth flushing fluid over night then washed it out with a hose.
The Following User Says Thank You to dddcccmack For This Useful Post:
Old 01-17-2007, 01:11 PM
xJayx xJayx is offline
Longwinded, but stick with it please! Had a 97 Taurus overheat and shutdown on the
Interstate about a year ago. I had run low on coolant somehow. Let it cool. Got coolant in it. Everything fine. Began losing coolant from reservoir cap later. Replaced Cap. Still losing. Replaced reservoir. Everything fine for while (six months). Radiator
develops slow leak. Flushed and stop leak put in. (Water was rust !) No help. Driven with slow leak for month (topped off twice). Radiator replaced and now something strange is happening. Sitting at a drive through the night after getting radiator replaced the temp has redlined! Shut the car off, let cool. Drive home. Now anytime I sit for 5 or more minutes the temp redlines. The fans blow fine. Once I start moving temp immediately normalizes. Even runs colder than normal while moving
for a bit and then stabilizes. What's even odder, while it's running hot, the heater
blows cold! Once I get moving the heater blows warm air. This fluctuates. Little cold,
warm. Sometimes it just blows cold while I’m driving, not enough to defrost! While driving its usually normal. The guy that replaced my radiator said it's
not the thermostat, because it would be stuck one way or the other. Both lines into the
firewall feel normal (hot,warm). He suggested a compression check to make sure it's not being lost through the head gasket, but I'm not losing coolant! Suggestions?? [email protected] gonzotrek at yahoo
The Following User Says Thank You to xJayx For This Useful Post:
Old 01-17-2007, 02:01 PM
Huney1 Huney1 is offline
We see the same senario many times and the water pump blades have a way of wearing down so if you try everything else and it doesn't work replace the water pump.
Old 01-17-2007, 05:04 PM
cardkleener cardkleener is offline
I have a problem that I nor my mechanic can figure out. I have a 98 Taurus wagon. I was losing coolant and found out that my reservoir was leaking. He replaced it and flushed out system. He saw something unusual that he didn't know what it was. It was a brown powder type substance. He did a chemical flush on it.
I then moved to another city. My car would run very hot. I put the heat on to see if that would reduce the temperature. I barely had any heat at all which I thought was odd. (this was in the summer months) I took it in and had the thermostat replaced and system flushed.
In the fall when I needed heat I barely had any. I took it back in and he said it was probably the heater core but he was reluctant to change it because it was a big job and expensive. So he flushed it out again.
I had heat for a couple of months. Then ran into the same problem, hardly any heat. He decided to change the heater core. When he was taking it apart he found a clog. He didn't change the core he just flushed it out again and told me to see how long it lasts.
About two months later I had the same problem. Hardly any heat. I searched forums and found a problem with the water pump fins corroding and breaking away causing clogs in the system. I suggested this to him but he figured if that was the problem it wouldn't push the water through properly and cause an overheating problem.
So now we are back to changing the heater core. I wanted to ask someone before I do this if they have had any experiences like mine. My controls are manual. I don't have a leaking problem. Just a no heat problem. He can't check the water pump unless he takes it out and apart. He figures there is calcium build up in the core causing clogs.
The Following User Says Thank You to cardkleener For This Useful Post:
