Old 10-25-2004, 01:01 PM
osok_deadeye_21 osok_deadeye_21 is offline
Window Fog Annoying!!!
Hey it is getting really cold here in idaho and my windows fog up a ton when i am driving to work. Is there any type of cleaning solution or what i can do to limit it or get rid of it. I know its a dumb question but I just thought i would ask.
Old 10-25-2004, 01:19 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
this works best for me to defrost the windows: turn A/C to defroster setting, then puch the A/C button (to yellow or green light), then just monkey with the temperature setting. i haven't used it in a long time, but i think i kept the temperature around the middle, but just mess around with it. the key is to push the A/C button, most people don't do that.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 10-25-2004, 01:25 PM
ok i see cause i dont use the ac button just the defrost with the heat on.
Old 10-25-2004, 01:26 PM
sLADe781 sLADe781 is offline
Re: Window Fog Annoying!!!
Linebckr49, you mean to have the AC on but the temperature on warm? Hmm....never did that one before.... I usually just have the temp on warm to high and then have it defrost with that one outside thing (I don't know what it's called hehe).
Old 10-25-2004, 01:36 PM
Thourun's Avatar
Thourun Thourun is offline
Send a message via AIM to Thourun
Having the heat on when it's cold outside will cause the watter molecules in the air (mostly from your breath) to slow down when they reach the cold area within a few milimeters of the glass and in doing so they will condense forming the "fog" on your windows. You can combat this by one of two ways, turn off the heat so that the windows are not signifigantly colder than the air within the car, or you could turn on the AC and ventilation and hope it is able to reduce the humidity in the car enough to lessen the buildup of the "fog". I use both when it starts to fog up, I turn the heat down to a medium level and turn on the AC.
1995 3000GT VR-4
Installed: ESP front precat eliminating downpipe, test pipe, RF-1008 K&N, Dejon tool Y pipe, 1G DSM BOV, MSD wires, Guted rear pre cat, ISSPRO EV Marine boost gauge, IPO MBC, EGR blockoffs, Palm m515 dataloger setup, NGK iridium plugs, SPEC stage II clutch 500ft/lb, 5300k HID plug and play setup.
Soon:Topline Engineering ground wires.
Old 10-25-2004, 02:15 PM
sounds good
Old 10-26-2004, 07:10 AM
privatebean privatebean is offline
Send a message via AIM to privatebean
I think Rain-X makes an anti-fog forumula to wipe onto the interior of windows. Although I couldn't tell you how it works, never used it.
Old 10-26-2004, 12:33 PM
Technical_Automan Technical_Automan is offline
Banned
Yeah Rain-X is the way to go, good stuff, works well.
Old 10-26-2004, 08:59 PM
my dad has that stuff i will ask him how it works.
thanks
