Old 10-25-2004, 10:57 AM
1PhatCX's Avatar
1PhatCX 1PhatCX is offline
clutch safety switch
ok, my car likes to crank over once and awhile. but when it doesnt theres nothing there, it sounds like i can hear the main relay click when i try to turn it over but theres nothing. could this be a sign of a worn or faulty clutch switch?? if so, where is it located exactly? (pics would help) and can i just take the wire off it so i can start it without the clutch??
Old 10-25-2004, 02:38 PM
Hybrid1990crx's Avatar
Re: clutch safety switch
i think its right down by the clutch pedal.
Old 10-25-2004, 09:23 PM
johnb16a2's Avatar
johnb16a2 johnb16a2 is offline
It could be the switch (at the top of the clutch pedal). Check here
But there might be a bad spot on the commutator in the starter that is causing the non-start. GL
Old 10-25-2004, 09:44 PM
vladlos's Avatar
vladlos vladlos is offline
Send a message via AIM to vladlos
hah, i have remote start on my car. i had to bypass the clutch interlock switch. if u feel ur clutch pedal arm all the way up u should see a kind of copper colored kinda ovalish tube (looks like one of those C02 container things). that's where ur wires are connected. there are two wires. if u want u can just bypass it buy soldering or splicing the two wires together and then u wont have to worry about pushing in ur clutch when u start up ur car. however, it is a safety feature incase u were to start ur car up in gear.
Old 10-26-2004, 10:28 AM
1PhatCX's Avatar
how the fuck would u solder it way up there?!?! i had a hard enough time adjusting it let alone even seeing the wires in there lol. but i did adjust it and it didnt have a problem starting lastnight so i think thats all it was. were gonna hafta wait and see now
Old 10-26-2004, 11:40 AM
2ndb18's Avatar
2ndb18 2ndb18 is offline
Send a message via AIM to 2ndb18
Ya its hella hard to get at. My car doesnt have one but ive seen them. you could unbolt it and bring it down though.
88 civic dx
Old 10-26-2004, 01:18 PM
vladlos's Avatar
yea, its pretty tough to get to. i've heard about people soldering them up there so i just suggested it. maybe these people are like stealth or something. all i did was splice them togethether, put electrical tape over it, and everything was sweet there after.
Old 10-26-2004, 02:39 PM
1PhatCX's Avatar
yea i might splice em once the sensor goes bad for good lol
Old 10-26-2004, 06:36 PM
JDMHondaFreak JDMHondaFreak is offline
I recently bought my rex, and i dont need to hold in the clutch to start it, is this a serious problem? if so how can i fix it? thanx guyz
Old 10-26-2004, 06:40 PM
V-K V-K is offline
Send a message via AIM to V-K
It's not really a problem, as stated before, just make sure your car isn't in gear when you attempt to start it without using the clutch.
Old 10-26-2004, 07:44 PM
88ReX 88ReX is offline
88 Crx's didnt have the clutch safety switch so what you are experiencing, JDMHondaFreak, is normal for an 88. If your problem reappears, 1PhatCX, I would suggest looking at your starter as someone else already mentioned.
"us FartoX guys are intelligent, excellent drivers who would never stoop to levels of pure testosterone"~Earlsfat
Old 10-26-2004, 07:54 PM
skotman's Avatar
skotman skotman is offline
my 89 DX doesn't have one either.
whether that's how it is, or that's how someone made it, i dunno.
Old 10-26-2004, 08:58 PM
1PhatCX's Avatar
i have a weird feeling its the switch, it didnt start the first time i tried tonight but i pushed the pedal harder and it went the 2nd time i'll adjust it a bit more and see what happens then but it hasnt happened as often now since i adjusted it
Old 10-26-2004, 10:26 PM
yea mines a 89, Thanx 88Rex
