Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 10-25-2004, 10:45 AM
thebachelor412 thebachelor412 is offline
01 Jgc Fuel Pressure Problems
i took my fuel pressure and got a low reading of about 25...i keep getting a code of p 171 and 174, which tell me my air/fuel mix is too lean.... what does this mean and what do i need to fix this problem... please help
Old 10-25-2004, 12:51 PM
dksob81 dksob81 is offline
Send a message via ICQ to dksob81 Send a message via AIM to dksob81 Send a message via MSN to dksob81 Send a message via Yahoo to dksob81
Re: 01 Jgc Fuel Pressure Problems
ok, is ur CHECK ENGINE LIGHT on all the time.
what lean mixture means, is the Engine has too much air and not enough fuel. are u expierence poor Performance?
Old 10-25-2004, 01:41 PM
very poor performance... usually takes about 10 tries to actually start the vehicle... feels as if not enough gas is getting to start the car..once on starts havin all types of problems, starts shaking, idles real low almost about to turn off...
Old 10-25-2004, 02:01 PM
Myrtle Beach Myrtle Beach is offline
I would inspect the fuel line and make sure it isn't crimped. the only other thing I can think of is changing the fuel pump. I would also inspect the filter while you have the tank down.
---99 Jeep Grand Cheerokee Limited 4.7 V8 -2" Lift -265X75 BFG---
Old 10-25-2004, 03:01 PM
yea I agree with Myrtle, b4 you do that, have the Fuel pressure tested. engine running lean shoudln't affect the startup pf the jeep, but it would affect the running of the jeep. the O2 Sensor(s) measures the fuel/Air mixture, but it does not activate till it is up to normal operating temp, b4 that the PCM is running the FUEL PUMP in an open loop. supplying fuel depending on the TPS signal, after it warms up the PCM gets signal from the O2 sensor(s) and the TPS to determine the amou8nt of fuel to be delivered,
here are a couple things to do, take your O2 sensor out and clean it with some Brake Parts Cleaner, get the Fuel pressure tested.
Old 10-25-2004, 03:57 PM
Dale Aeppli Dale Aeppli is offline
HI, IF YOU HAVE 25 LBS. OF FUEL PRESSURE. YOU EITHER HAVE A BAD FUEL FILTER OR THE FUEL PUMP IS GOING BAD. DALE
[email protected]
