Old 10-25-2004, 09:36 AM
blondiechick blondiechick is offline
Send a message via AIM to blondiechick
CO2 Dragster... HELP
I am in an Auto Cad Class and our current project is to build a CO2 Dragster out of ballsa wood(sp?) . I was wondering which would be the best type of design to win =) ... if anyone has any pointers it'd be greatly appruciated
THANX
You're not your job.
You're not how much money you have in the bank.
You're not the car you drive.
You're not the contents of your wallet.
You're not your fucking khakis.
You're the all-singing, all-dancing crap of the world.
Beauty is in the eye of the beer holder...
Old 10-25-2004, 12:10 PM
white97ex's Avatar
white97ex white97ex is offline
Send a message via AIM to white97ex Send a message via Yahoo to white97ex
Re: CO2 Dragster... HELP
give us some specs. what weight limits, material restrictions. just post all the rules.
My name is Russell, feel free to use it.
I'd rather be hated for Who I Am than be loved for Who I Am Not
Old 10-25-2004, 01:02 PM
gasman03's Avatar
gasman03 gasman03 is offline
ahh, CO2 cars, that takes me back,
first off, make it sturdy, and strong, I was able to finish third in my class becouse everyone's car I ran against broke before the finish. and your also gonna want to put alot of weight near the C02 bottle, helps the rear wheels with traction, becouse odds are the front wheels will never touch the ground
Old 10-25-2004, 02:31 PM
DSM-Mark's Avatar
DSM-Mark DSM-Mark is offline
Actually, since the rear wheels really provide no motivation force for the car, you really don't need any weight over them.
These cars are a balance of weight vs. aerodynamics vs. strength. And skill in crafting them is also important.
When I built mine, the rules specified a height, a minimum thickness and width and also various specs for other things. Mine was an arrowhead design in the front, which rapidly became a 1 cm diameter neck after the front axle that was about 4" long (for length requirements) then bubbled out to accommodate a CO2 cartridge. A single fin on the top brought my total height to the requirement.
A couple of tips to score better:
1: make sure your axles are well lubed. The C02 runs out halfway down the track, and it's a coast from there. Besides, friction = bad.
2: Think very carefully about paint. Your instructor might tell you to paint the car, but it really adds a lot of weight. Haha, funny right? Nope. Consider that the balsa you use is incredibly light. Paint is not so light. I remember we coated ours with a primer sealer, then a body colour (sometimes 2 or 3). As i recall, some people ended up with about a 25% increase in weight. Just go au naturel. no paint. You'll probably do better without it.
I work slowly!
Old 10-25-2004, 06:29 PM
SLAYTANIC_1134's Avatar
SLAYTANIC_1134 SLAYTANIC_1134 is offline
I think dsm - mark has hit it right on the nose. Friction is going to be a big factor along w/ reliability. I think if you concentrate on those two things you will have a real winner. Make sure you let us know how it goes! Good Luck!!
Old 10-25-2004, 08:14 PM
JDM Wagon JDM Wagon is offline
i just did an internet search for CO2 dragsters and there is a lot of info out there. it appears that the rail design is the best. that is where the wheels are tucked under the body of the car.
as far as axles go, i see a lot of these so called nitro axles for pinewood derby cars that will probably work with a co2 dragster.
Scale Speed Garage
Old 10-27-2004, 09:02 AM
We are given a kit. So the balsa wood is mandatory.
Body length -
min=200mm max=305
Body height w/ wheels -
Max=75mm
Body mass (completes car w/o CO2)-
min = 60g
Body width at axles, from and back -
min=35mm max=42mm
Vehicle total width(including wheels)
max=90mm
Thanks for your help. If you want any other restrictions let me know
Old 10-27-2004, 03:23 PM
parts parts is offline
It's been 20+ years since I built one.
A few tips:
Place the wheels on an axle and chuck it up in the drill press. Then use sandpaper or a file to make the wheels round. Most of the kit wheels will have a high spot.
Then chuck the axles up and use very fine sandpaper and later steel wool to polish the axles to almost a mirror finish.
As for the body, a teacher in college had a computer designed body. It was just a rail design except for where the rear axle was placed. The axle was placed forward enough that when an full CO2 bottle is place in it the tail would go down (do a wheelie). Place an empty CO2 bottle in and it would set level. His car took state that year.
Old 10-31-2004, 08:46 AM
Thanks for the tips
