Old 10-25-2004, 08:56 AM
jtopel jtopel is offline
Question 1989 Cacalier Heater Core
I just purchased a 1989 cav the engine is super clean and so is the interior but it needs a heater core replaced I have done this before on a ford and on a chevy truck but I was wondering if anyone could give me some tips on how to do this on the cav? on the ford I did the dash was never quite right agian (thats what i get for owning a tarus)
thanks,
James
Old 10-25-2004, 12:27 PM
Leader100 Leader100 is offline
Re: 1989 Cacalier Heater Core
thanks,
James
James...what makes you think that the problem is with the heater core?
is it leaking?
What symptoms does the vehicle have...why not a bad radiator..water pump or thermostat?
Old 10-25-2004, 12:58 PM
bad coolent smell in passanger compartment, i bypased the heater core lines smell went away, also coolent level is now staying normal
Old 10-25-2004, 01:30 PM
4dr92cavi4cyl's Avatar
4dr92cavi4cyl 4dr92cavi4cyl is offline
Yup, Heater Core, seems like these HCs that GM used SUCK. I have put THREE HCs in my 92. They leak every summer. My 92's is about as easy as it gets to get to. I've heard the horror stories about pulling the whole dash! Well, GM actually did something right, the heat box is directly behind the radio, under the dash in my 92, you have a 89 but maybe it's the same.
There's a smaller piece that has two hoses, two screws, and a snorkel looking piece for the bottom vents. It's easy to take out, and hard to put back in, it fits between the heat switch flap and another piece of plastic or something. After that's off proceed removing the bastard screws off the box. Some are hard to find but you'll know if you missed one, my box was cracked but I finished it off trying to take it off without removing all of them, now I have a new one from a junkard. Once you get the box out there's two metal strips holding the HC in place.
Good Luck
