Old 10-25-2004, 09:38 AM
cody spears cody spears is offline
Oil leaking form back of block
There is a sensor where im leaking a little bit of oil, i was wandering if anyone has had this problem before and know what this sensor is called. It is leaking enough where there is oil on the backside of my engine.
Old 10-25-2004, 03:22 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: Oil leaking form back of block
You sure that is where the oil is coming from?
Have you checked that maybe it is a valve cover gasket leaking?
Old 10-26-2004, 08:17 AM
The head is clean from the top of the valve cover to where the head bolts to the block there is just oil on my block and i didnt know if it could be one of those sensors on the block if anyone could help id appreciate it.
Old 10-26-2004, 09:32 AM
Classicrocjunkie's Avatar
Classicrocjunkie Classicrocjunkie is offline
Lifted GMT-360!
Send a message via AIM to Classicrocjunkie
clean it off and see where its really leakin from...
Please don't PM me with your J-body Issues. Post appropriately in the forums,
and I will toss my opinion in your thread if I have anything to help. - Thanks!
2006 Chevrolet Trailblazer
2010 Glastron GT 205XL
Old 10-26-2004, 10:44 AM
EnjukuRacing240sx EnjukuRacing240sx is offline
i hope its not your rear main seal man...
Old 10-26-2004, 12:23 PM
BlazerLT's Avatar
AF -Advisor
Re: Re: Oil leaking form back of block
Yes, clean it so you can see.
Oil doesn't leak from the top of the valve cover, it leaks where it attaches to the head.
Old 10-27-2004, 08:24 AM
Where is the rear main seal? I think that the leak is coming from the oil sending unit,
Old 10-27-2004, 05:56 PM
public's Avatar
public public is offline
Oil can leak from a valve cover but you would see that on the intake manifold. It could be the head but that would be unlikely if it is running properly.
On the back of these engines you have a oil sending unit This is most likely your leak. There is also a crank position sensor but that is almost to the bottom so the oil would just fall off. Good Luck.
