Old 10-25-2004, 08:35 AM
RKINGII RKINGII is offline
Question cap and rotor
Got a '95 S10, with 4.3L V6. How do I change the cap and rotor? Do I have to remove the intake manifold to get at those?
Thanks
Old 10-25-2004, 03:06 PM
busa_4 busa_4 is offline
Re: cap and rotor
i am not familiar with the 1995 but the cap should be clipped on and the rotor is held in place with some form of screw or just held on by a pressed fit. you should not have to take the intake off. some advise! remove only one plug wire at a time when replacing the cap otherwise if your not familiar with the firing order you might mix up some wires.
Old 10-26-2004, 05:36 PM
dmbrisket 51's Avatar
dmbrisket 51 dmbrisket 51 is offline
Send a message via AIM to dmbrisket 51
Re: cap and rotor
Should take off the air intake hose into the multi port, other then that, no no manifold removal
Old 10-26-2004, 05:39 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: cap and rotor
Thanks
Do you have the TBI or CPI injection on your truck?
Old 10-27-2004, 06:46 AM
Re: cap and rotor
Throttle body. The distributor (horizontal plug wires) is really buried in there. I have a Haynes manual, and the photo (for clarity) they show for cap & rotor has the manifold off. I sure don't want to go thru that.
Old 10-27-2004, 10:03 AM
Mikado14 Mikado14 is offline
Re: cap and rotor
Get a piece of paper and pen or pencil. Trace the wires from each cylinder to the cap and make a diagram. After you have your diagram, pull all the wires off of the cap. You may also have to unplug a few wires to move a harness out of the way but you will find that the plugs are idiot proofed. This should allow you a little more room to get in there. After the cap has been changed, use your diagram to install the wires.
Old 10-27-2004, 10:24 AM
Re: cap and rotor
Sounds like a plan! Thanks a lot for the reply. That's what I was wondering about, if I had to move a few things to get at it. Diagram is a great idea! Raining out today, so it may be a good time to "git 'er done". I did take the wheels off to get to the spark plugs. Much easier that way. I wouldn't have done that, if I didn't have an air wrench. Thanks again
Old 10-27-2004, 05:43 PM
BlazerLT's Avatar
AF -Advisor
Re: cap and rotor
What I do is take the new cap and when I remove the wires from the old cap , I put them directly on the appropriate place on the new cap.
Then when you are ready to install the cap, you pop it on, screw it down and you are done.
No mistakes or confusion.
