Old 10-25-2004, 07:59 AM
misracegirl misracegirl is offline
Levels 1 and 2 not working
I have a 2001 Grand Am GT and the levels 1 and 2 are not working on the heat and A/C. How do I fix this and what part needs replaced?? Any information would be helpful. Thank You
Old 10-25-2004, 10:53 AM
whataboutbob whataboutbob is offline
Send a message via AIM to whataboutbob
Re: Levels 1 and 2 not working
Blower motor resister. Very common on Grand AM and Grand Prix. i found a website that offers OEM GM online catalogs 24-7. had the parts shipped to my home cheaper than buying from my local dealer. www.gm-car-parts.com
Old 10-25-2004, 02:33 PM
GTP Dad GTP Dad is offline
Pontiac Guy
The blower motor resistor is the problem for sure. The resistor is located next to the fan usually under the dash. It is not hard to change just hard to get to. You sometimes need to remove the fan to get the resistor out. As far as where to purchase it costs between $30 and $40 from a dealer and you can pick it up locally. Good Luck!
Old 11-12-2004, 07:59 PM
mrelmo mrelmo is offline
before you spend alot of money look for a vacum leak the gray or black hose behind the driver side headlight will be shaffed and leaking, tough to see you might have to move the battery, cut the bad piece out and splice with washer hose
