Old 10-25-2004, 01:43 AM
DA_holtum DA_holtum is offline
Send a message via AIM to DA_holtum Send a message via Yahoo to DA_holtum
Check Engine light is on
I have a 96 GA SE my check Engine and ETS lights are both on. this has happened once before, but I got the engine changed and it was fine. Both times it's happened on long trip where I've travelled over 100 miles non stop. Any suggestions. Cause I feel its important to have ETS.
Old 10-25-2004, 07:22 AM
lou S. lou S. is offline
Re: Check Engine light is on
Get your diagnostic codes read for free at autozone. As far as your ets light being on don't you have a button on your gear shifter that you can press in to activate or deactivate your ets?
Old 10-25-2004, 08:01 AM
misracegirl misracegirl is offline
It could be that you gas cap is loose. Try to tighten it and see if the light goes off.
Old 10-25-2004, 09:33 AM
The button on the gear shifter doesn't affect it at all, bot like it normally does. I'll have to check the gas cap later when I go out.
Old 10-26-2004, 12:22 AM
I went to the auto parts store and got it checked with a scanner. It's either my O2 sensor or catalytic converter.
Old 10-26-2004, 07:08 AM
Did they give you the code numbers or is that what they just told you? Both parts vary a lot in price. As far as your ets not sure about the circuit but check to see if a fuse is out. Can't believe emissions would be tied into traction control.
Old 10-27-2004, 12:53 PM
they gave me the print out from the device they used. I've checked all my fuses and they are fine. Though my tail light/dash fuse dos blow often they are all fine. I was thinking the same thing about the traction control being ionvolved.
Old 10-28-2004, 08:15 PM
Forkliftguy's Avatar
Forkliftguy Forkliftguy is offline
Re: Re: Check Engine light is on
It could be possible, I'm not overly familiar with the ETS except for the fact that I always turn mine off, but it works by controlling the engines power output so it could very well depend on emissions depending on how sophistacted the system is. Just my 2 cents.
Marc
Old 10-28-2004, 10:05 PM
Thank you all, I've been looking into buying a high flow "cat" and tunable exhaust even before I encountered this prob. so it just puts more importance on it. can anyone tell me the diameter of my exhaust pipe at my catalytic converter and muffler?
