Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 10-24-2004, 11:28 PM
complex_eclipse complex_eclipse is offline
Send a message via ICQ to complex_eclipse Send a message via AIM to complex_eclipse Send a message via MSN to complex_eclipse Send a message via Yahoo to complex_eclipse
Angry 4G63 Any alternatives
Aight i have a 1992 early production Eclipse with a 4g63 non turbo
i just rebuilt the stupid thing i got it all done and it ran for a few seconds and stalled then when i tried it again the started just clicked buzzed and few other noises. me knowing about the reputation with the valves i crawled under the car and tried turning the motor over manually but all heard was the timeing belt slipping i am positive the timeing belt was on perfect when i put the engine in anyone have ne input on what could be wrong or any engines i might be able to swap in that do not have a problem bending valves
Old 10-25-2004, 12:13 AM
tfoti tfoti is offline
Testiklees
Send a message via AIM to tfoti Send a message via MSN to tfoti
Re: 4G63 Any alternatives
did you check it again after this happened to see if the timing marks were all lined up? if not then you slipped time, and probably bent valves.
Tim
1990 Talon AWD
2.3 stroker, 8.8 wiseco, FIC 750's, DSMLink,
PTE SCM5031
Old 10-25-2004, 09:59 PM
i'm not sure i haven't been able to work on it since the night i put it in but i did try to turn the motor over by the cam gears like the book told me to and nither cam would budge so i'm not sure what is going on with the dumb thing
Old 10-26-2004, 06:29 AM
kjewer1 kjewer1 is offline
AF - Advisor
Turning the motor over by the cams is a bitch, and I would never recomend that. It is NOT designed to work that way, and you are very likely to skip a couple teeth if you do it the wrong way (you have to turn away from the opposite cam gear, never into it, and dont turn the motor backwards, the tensioner wont work properly).
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 11-03-2004, 10:07 PM
i found out that my intake cam locked up on me i don't think i bent any valves but i haven't had time to try and start it yet after i fixed the cam issue
