Go Back   Automotive Forums Car Chat > Buick > Regal
Old 10-24-2004, 09:57 PM
kreetz kreetz is offline
Buick Regal Blinker Problems
I have a 91 Buick Regal. My blinkers to not blink, and sometimes will not light up. I have to hold the blinker either down or up to get them to blink, and sometimes I have to move the blinker arm up and down to simulate blinking. Could these be a problem with the contacts in the steering wheel column?
Thank you,
Kevin
Old 10-25-2004, 09:26 PM
-Josh-'s Avatar
-Josh- -Josh- is offline
Automotive love doctor
Send a message via AIM to -Josh-
Re: Buick Regal Blinker Problems
By the sounds of it you need a new multifunction switch. I'm not sure how expensive those can be on your car but they CAN be expensive.
Self improvement is masturbation
AF User Guidelines
What is a mippie? - click
Old 10-25-2004, 09:48 PM
JoeyBoy JoeyBoy is offline
You can pick a blinker switch up at a pull it yourself salvage yard for $10-$15. I paid $12.70 for mine the day brfore yesterday.
Old 03-27-2005, 10:02 PM
wally43 wally43 is offline
My 91 regal has the same problem. If the steering wheel is turned to a certain position everything works fine. Even the steering wheel radio controls. I am thinking of a maybe a short in the steering column wiring. But I need my car daily and don't have time to tear it apart, so I live with the nucense.
Old 04-24-2005, 03:27 PM
y2kpa2's Avatar
y2kpa2 y2kpa2 is offline
Village Idiot
on my 88 regal you have to pull back the turn signal switch a little bit when using the left signal for it to come on
Old 04-24-2005, 03:29 PM
y2kpa2's Avatar
Village Idiot
any one know about gas gauge or odometer problems in the dash cluster, gas gauge works intermittently odometer quit years ago!
Old 04-26-2005, 10:43 AM
maurycy maurycy is offline
Guys,
If you have the multifunction switch (wipers, blinkers, cruise, ...) it is the switch that is causing problems. I had the same problem with my 96 Regal. Switch costs $90 at the dealer (I would recommend getting new one) but the labor might be expensive as the steering wheel has to come off for the switch to be installed.
Maurycy
Old 07-01-2005, 02:42 PM
scottb6674 scottb6674 is offline
Re: Re: Buick Regal Blinker Problems
Originally Posted by maurycy
Guys,
Maurycy
I greatly appreciate the insight. My 95 regal has a similar problem in that intially the cruise control would disengage when I made a left hand turn.
Now, the left hand turn disengages the brake lights. So it is an obvious short. Since I have been training as an electricians apprentice for the past several months, I feel confortable fixing the wiring (if possible).
But since I'm not a mechanic, how do I remove the steering wheel and is there anything special that I need to do so that I don't damage or prematurely engage the air bag?
Any help you could give would be greatly appreciated.
