Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 10-24-2004, 07:05 PM
tnorris tnorris is offline
2001 Tahoe Brake Problems
I am having problems breaking some times under speeds of 5mph. My ABS is not lighted, nor has it been on. What I experience is something in sorts of the ABS activating. The break pedal does not go down as far as normal and then when I let off of the breaks and then re-apply the problem goes away. This problem does not occur all the time, but is starting to happen more often. I have read some problems with the ABS sensor, but wouldn't the light be on or something? Any help would be greatly appreciated.
Old 10-25-2004, 09:12 AM
lthrnck1775 lthrnck1775 is offline
Brake Probs
I have a 2000 Suburban - same problem. Dealer said bad hub and bearings....causing ABS to misread? Both will cost $850 to repair. I never heard of such a thing I have only 65k miles!!!
Let me know if oyu hear any different. I hope there is a recall...LOL
Kevin
Old 10-25-2004, 10:29 AM
kannegk3571 kannegk3571 is offline
We had the same problem on our 2001 Tahoe. The dealer put a new speed sensor on one of the wheels and it has been fine ever since. I don't remember the cost right now, but I am sure it was less than $200.
Old 10-25-2004, 12:44 PM
ryan09170 ryan09170 is offline
I had a similar problem on my 2000 Tahoe. Under 5mph the ABS would activate and cause the brakes to not engage properly. Almost went through an intersection because of it. What was happening was the ABS sensor got pushed up due to metal corrosion under its mouting location. Apparently the gap between the sensor and the ring in the hub is very sensitive. The sensor was tough to get out without damaging it, but once I cleaned off the corrosion on the mount, haven't had a problem since (about 1-1/2 years).
Old 03-29-2005, 05:03 PM
oleo oleo is offline
Re: 2001 Tahoe Brake Problems
I am having the same problem with my 98 tahoe. Is it an easy fix for the fixit yourselfer or is it prudent to take it to a dealer??????
Old 04-13-2005, 07:06 PM
chokonit chokonit is offline
there is a tsb on this problem that can be found on the alldata.com site. some people have actually experienced total brake falure...
Old 05-09-2005, 06:11 PM
Tnorris refer to the Attn: Recall for ABS problems , the thread was started by Daver84. Their is some valuable info in the thread.
Oleo from Lodi
