Old 10-24-2004, 02:21 PM
1986Z28's Avatar
1986Z28 1986Z28 is offline
Has a Camaro
Send a message via MSN to 1986Z28
body putty
what kind of body putty do you guys use for smoothing lines and holes, where can i get it?
Formerly Blownalcoholboy
1986 Z28, 400ci SBC, Twin borg warner billet S467 turbos, Reid case powerglide, Moser 9". Holley EFI, Boost Leash. 950RWHP on pump gas, 1200rwhp on race gas (22 psi)
Best ET 1/4: 8.35 @ 170mph (275 drag radial)
Best ET 1/8: 5.44 @ 132mph (275 drag radial)
Best 60': 1.31 on the back tires (275 drag radial)
AF User Rules/Guidelines
http://www.automotiveforums.com/vbul...uidelines.html
Old 10-24-2004, 02:23 PM
mike@af's Avatar
mike@af mike@af is offline
Captain Over Engineer
Re: body putty
Tamiya Grey Putty, or Tamiya Epoxy putty depending on the size of the job.
-Mike
Old 10-24-2004, 06:21 PM
StephenDeli's Avatar
StephenDeli StephenDeli is offline
Send a message via AIM to StephenDeli
Re: body putty
I use tamiya grey putty like Mike for seams and occasionally holes. But I am beggining to find out that CA cement fills holes very well and sands super easy.
Current Projects- Ferrari F189 ON HOLD
Ferrari 360 Spider
Future Projects-04' Corvette Z06, Enzo, F1-2000
Old 10-24-2004, 07:03 PM
Tikiman's Avatar
Tikiman Tikiman is offline
Re: body putty
I use Revell Model Filler and/or Humbrol Model Filler.
Old 10-24-2004, 09:26 PM
JTRACING's Avatar
JTRACING JTRACING is offline
J.E.T.
I use Squadron putty, or super glue mixed with some baking soda
Old 10-24-2004, 11:00 PM
hirofkd's Avatar
hirofkd hirofkd is offline
Re: body putty
If it's for a small hole or a shallow sink mark, I use super glue.
Hiroaki Fukuda
Old 10-25-2004, 02:25 AM
Wheelin75r's Avatar
Wheelin75r Wheelin75r is offline
Re: body putty
Like Tikiman, I also have a good result with Revell Model filler.
Old 10-25-2004, 06:33 AM
mike@af's Avatar
Re: body putty
Superglue does work good, the only down to it is that it can be hard to see when sanding.
-Mike
Old 10-25-2004, 09:11 AM
Zlaja_'s Avatar
Zlaja_ Zlaja_ is offline
Send a message via MSN to Zlaja_
Re: body putty
thats why you should spray on a layer of primer after sanding to detect flaws
Old 10-25-2004, 11:39 AM
patate's Avatar
patate patate is offline
Re: body putty
I use bondo or fiberglass resin (ok mayybe im a bit extreme lol)
Old 10-25-2004, 12:17 PM
mike@af's Avatar
Re: Re: body putty
Bondo's Fiber Glass resin is made for mixing into fiberglass.
-Mike
Old 10-25-2004, 12:41 PM
spidereddie's Avatar
spidereddie spidereddie is offline
Send a message via AIM to spidereddie Send a message via Yahoo to spidereddie
Re: body putty
You know what works great?
I use SEARCH. It works great for filling gaps very well, pretty cheap and it comes with a money back guarantee. Only problem is that it's kinda cumbersome.
heheh
Ed-
