Old 10-24-2004, 08:59 AM
geofroley geofroley is offline
Send a message via AIM to geofroley
Making a turbine for this turbo
http://www.imbalancechemical.com/luc...cs.asp?catid=4
Go to the centrifigul supercharger one (for those of you that don't know, a centrifigul supercharger is a turbo compressor spun by a belt) That compressor is AWESOME, but I can't figure out how to make a turbine for it. Any ideas?
Old 10-24-2004, 11:52 AM
AstroRide44's Avatar
AstroRide44 AstroRide44 is offline
Re: Making a turbine for this turbo
that man is amazing
"You can go far with a smile, but you can go farther with a smile and a flamethrower"
Keep it Wingless.....
Old 10-24-2004, 01:11 PM
MidMazar's Avatar
MidMazar MidMazar is offline
thats a great howto!!!
In Progress
Old 10-24-2004, 01:32 PM
Q-DawgVFR Q-DawgVFR is offline
I've used a gear from a watch for this purpose (sorry, but I have no picture to show). The gear was basically just a flat peice of thin brass with teeth around the edges and a shaft in the center. I simply made eight pie cuts around the edge of the gear (but not right up to the shaft) with my hobby knife. Cut off the extra length you dont need from the outer edges. Then using tweezers, twist the pie cut sections into the vanes you desire. Cut off the shaft from one end of the gear, since it is only present on one side. This is a great mod for detailing race car setups which have no air filters on the turbo inlet, or for a diorama where you want some car parts laying around. Please ask me questions on any part you did not understand and I will try to help further.
Old 10-24-2004, 02:45 PM
white97ex's Avatar
white97ex white97ex is offline
Send a message via AIM to white97ex Send a message via Yahoo to white97ex
one thing you need to take into consideration is that you wont see the turbine, once the piping is all ran, it is not shown
My name is Russell, feel free to use it.
I'd rather be hated for Who I Am than be loved for Who I Am Not
Old 10-25-2004, 11:01 PM
weaponCIVIC's Avatar
weaponCIVIC weaponCIVIC is offline
thats the best how to on a turbo/supercharger ive seen yet. ive already started to make one, its pretty easy i am using all plastic though.
http://www.automotiveforums.com/vbul...d.php?t=620111
"Look as far as the eye can see, go there, then look farther."
Old 10-25-2004, 11:25 PM
lancer07 lancer07 is offline
what size piping did you use
Old 10-26-2004, 12:04 AM
white97ex's Avatar
i made some. check out the progress thread in my sig. i used 1/8th inch steel rod with .062 solder wrapped around it. the plumbing solder used in the tutorial above is quite large
Old 10-26-2004, 03:31 PM
Re: Re: Making a turbine for this turbo
Will it fit in the engine compartments of Revell kits? They have super small compartments.
Old 10-26-2004, 10:06 PM
white97ex's Avatar
check my progress thread you'll see how i made it fit
