Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 10-24-2004, 07:16 AM
ufatbasted ufatbasted is offline
1991 Camry Heat blows cold only
Going to buy a used 91 camry 56,000 miles for my son to use a college. Milage to low to pass on.
Only thing wrong witht he car is that the heat blows cold air only.
Anyone here know what it may be. Seller had a quote of 500 to fix but does not know whats being fixed.
I would like to try to fix myself.
Old 10-24-2004, 12:40 PM
burchard burchard is offline
Re: 1991 Camry Heat blows cold only
Check close to the firewall the connection of the heating to the coolant lines. There is a mechanical valve that allows the passage of hot coolant to the heating radiator. Some times the screw that connects the hot/cold air switch to that valve is loose and does no move the valve. Hope is that.
Old 10-24-2004, 09:44 PM
trexx85's Avatar
trexx85 trexx85 is offline
could be the heater core has gone bad
Old 10-25-2004, 07:15 AM
Thanks for the replies
Any idea how much to replace the heater core it thats the problem?
Seller was quoted 500.00
Im commiting to buy this car today 91 4 cyl auto with 56,000 miles in near mint cond except for the heater. Paying 2500 seller dropped the price based on kbb value to adjust for 500 heater repair.
Old 10-25-2004, 12:09 PM
Joe W Joe W is offline
Double-check the coolant level as low coolant will also cause this,also if the thermostat is stuck open or missing the temp guage won't go to normal and the air won't be hot.
