Old 10-24-2004, 04:36 AM
contimheokho contimheokho is offline
Send a message via AIM to contimheokho
help guys!! my car wont start!!
im having trouble wit my rex. last 2 weeks, i went on the freeway. suddenly, the engine just turned off, i tried to turn it back on. but the problem is it wont start again. it was 8 am in the morning. i got it towed back durin around 2 pm in the afternoon. so it was a pretty good tanning out there. i tried everything, i changed out the distributor, the alternator, and the battery. but it still wont start. i tried to check for spark, but there's no spark. the main relay are fine. plz help me!!! give me suggestion. thanx guys. srry bout the long post
Old 10-24-2004, 04:55 AM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
Re: help guys!! my car wont start!!
Is the ECU throwing any codes?
Did you check the timing belt?
Also did you check to see if you have a good engine ground?
Old 10-25-2004, 01:24 PM
Re: Re: help guys!! my car wont start!!
no ecu codes. i didnt touch the engine ground since i got the car. how do u check the timing belt? srry, im pretty new at this.
Old 10-25-2004, 04:23 PM
ef four door's Avatar
ef four door ef four door is offline
id be willing to bet its your distributor rotor. the screw holding it on probably fell off. it happened to me a while back.
1989 civic lx four door, MPFI SOHC ZC powered, SOLD
1988 civic dx four door, D15B VTEC...permanently converted to obd1
Old 10-25-2004, 05:02 PM
Forunn Daberator
http://www.binghamtonlife.com/manual/2gsm/default.htm that will show how to do all the stuff thats been braught up here.
Old 10-25-2004, 05:08 PM
clawhammer's Avatar
clawhammer clawhammer is offline
To check the timing belt you need to take off the valve cover and the timing belt cover on the CRX. If it snapped than it will be obvious
Old 10-25-2004, 06:29 PM
but the thing is that. the engine just shuts off when i was running.
Old 10-25-2004, 08:32 PM
rex1212 rex1212 is offline
my car did the same thing while i was driving. It jus cut off on me and wouldnt start nomore and that was like a month ago. havent got it fixed yet been having problems. But i changed the module and i tested the coil and that was good. I had new spark plugs, wires, rotor, and the cap itself. But now i still dont get no spark to the spark plugs and i think the ground is horrible for the engine on mine but im not sure. Anyone got any suggestions.
sry didnt wanna post the same question.
i think i might have pics.
Old 10-25-2004, 10:32 PM
johnb16a2's Avatar
johnb16a2 johnb16a2 is offline
If the timing belt snapped the car will just shut off. Because if the timing belt snaps the valvetrain will stop and the car will not run.
If you don't want to take the valve cover and timing cover off to check the belt you can just take the distributer (dizzy) cap off and see if the rotor turns when you start the car. If the rotor doesn't turn your timing belt probably snapped.
While you're there you can check to see if the rotor screw fell out (causing the rotor to stop turning and in turn causing the engine to stop). GL
Old 10-25-2004, 10:36 PM
johnb16a2's Avatar
My car did something similar, it would just cut out, like someone flicked a kill switch. Long story short, I replaced the distributer (dizzy) and that seemed to have fixed my problem. GL
BTW, Hi Noobs, welcome to the forum!
Old 10-25-2004, 10:44 PM
Re: Re: Re: help guys!! my car wont start!!
i have my timing belt cover off long time ago. the belt didnt snap, i tried to test for 12v on the distributor. but i only see one wire lights up, the rest dont.
Old 10-25-2004, 10:51 PM
johnb16a2's Avatar
Re: Re: Re: Re: help guys!! my car wont start!!
Please clarify, I don't quite understand.
Old 10-25-2004, 11:34 PM
crx91's Avatar
crx91 crx91 is offline
di you replace the whole dizzy.or just rotor and cap.it could be ur timing.if ur car is not timed right than u will get no spark.does the car turn over at all?
Old 10-25-2004, 11:48 PM
i took of the dist today. and start the engine. the cam spins, the timing belt spins. but the thing is, the camshaft that go to the dist wont spins. it just stay one spot. what's happening?
Old 10-25-2004, 11:52 PM
johnb16a2's Avatar
The rotor doesn't spin? Did the rotor screw fall out?
