Old 10-23-2004, 11:45 PM
tharrison57's Avatar
tharrison57 tharrison57 is offline
89 Lesabre won't start when damp
First of all, thank you for allowing me to keep my 89 Lesabre with 177,000 on life support ! Just reading the posts has been a tremendous help.
Now the problem. My '89 with 177,000 on the 3.8 purrs like a kitten ... if I drive it every day. If it doesn't get driven for a couple of days & it sets out in the rain, it must get aggitated & won't start. Spins fine, just acts like there is no fire. I've done plugs, wires, a coil pack & module within the last 3 months, but it didn't seem to help this problem. Never have ANY kind of check engine light, so I don't think there would be any codes to retrieve.
Any help would be appreciated as the leaves are falling from the "shadetree" fast ! Thanks in advance.
Old 10-24-2004, 11:48 AM
yogi_123rd yogi_123rd is offline
Re: 89 Lesabre won't start when damp
Spark and timing are controlled by the crankshaft position sensor and the camshaft position sensor. Suspect that the moisture may be shorting out the signal.
When your problem happens, you should check for spark then. You could also throw a bucket of water onto those sensors (front of engine) while the engine is running to see if you can stall the engine out.
Old 10-24-2004, 02:53 PM
avatar307's Avatar
avatar307 avatar307 is offline
A bucket of water. That's classic. I love it.
That is literally the best way to confirm the cause of the problem, but it just sounds so wrong.
"Sleeping is the only thing keeping me from killing all the stupid people on this planet."
"Of one that loved not wisely but too well;" (Othello, Act 5, Scene 2, Line 344)
