Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '71-'87 Civic | CRX
Old 02-19-2002, 09:00 PM
91HBSi 91HBSi is offline
Send a message via ICQ to 91HBSi Send a message via AIM to 91HBSi Send a message via Yahoo to 91HBSi
stuff leaking onto my rims
Ok, I think it is the CV; I am just making sure. There is oil or some kind of black fluid leaking onto the inside of my rims. It makes little black spots on my rims and they are a pain to get off. If it is the CV then can I fix it, or do I have to replace some stuff?
Lexus SC300 (Kazera KZa 18"x8.5" 245/40 (front), 18"x9.5" 275/35 (rear)... put on hold.
Civic Hatchback Si (I/H/E, d16z6 head, H&R springs/tokico blues, etc.)
94 Prelude Si (Sold!)
Former PureHonda.com member since Dec. 00
"For to me, to live is Christ and to die is gain." Pilippians ONe21
Old 02-19-2002, 09:20 PM
EightOhOne's Avatar
EightOhOne EightOhOne is offline
CV boot's torn most likely...just pull off your wheel, and look around, you will be sure to see a tear, or grease all over the front suspension as well. Id just replace the whole axle, unless you like getting real messy
as for getting the grease off your wheel, try dishsoap(a lot) and water
Old 02-19-2002, 09:23 PM
Setanta's Avatar
Setanta Setanta is offline
Send a message via ICQ to Setanta Send a message via AIM to Setanta Send a message via Yahoo to Setanta
CVs use grease, not fluid. I would be be checking my brake lines and hoses very very carefully. Also check the caliper piston seals - it might be time to have a new seal kit put in as well as having the bores honed.
Check your CVs anyway, look closely for splits although in my experience the grease gets thrown upwards no outwards.
Final thought might be that it is simply brake dust that has hardened - but you're saying it's fluid.
'99 PY DC2R
'85 BBS BMW E30
RIP '90 JDM EF9 Civic SiR
www.performanceforums.com
Old 02-19-2002, 09:49 PM
kris's Avatar
kris kris is offline
Off playing with fire.
Grease is a fluid. Just a really thick fluid.
Old 02-19-2002, 09:52 PM
90CRXZCSi's Avatar
90CRXZCSi 90CRXZCSi is offline
Send a message via AIM to 90CRXZCSi Send a message via Yahoo to 90CRXZCSi
And when grease heats up it could become a liquid so it is possible it's the CV boot ripped.
2004 Sonic Blue Ford Ranger XLT
2001 Liquid Grey Metallic Ford Focus ZX3
1995 Integra GS-R - Parting out
Old 02-20-2002, 12:26 AM
shatshadarach shatshadarach is offline
if it were brake fluid, youd have a little bit worse situation than stains on your rims, brake fluid eats things, the clear coat on your rims would be toast. if it were grease, it should still have the greasy texture when its on your rims, otherwise grease would only be good for one time use right, because if its a pain to get off now, then imagine what would happen to your cv joints...right?? and when grease heats up, it doesnt get that liquidy, otherwise you would have to seal your bearings on your spindles on a rwd car because youd have no grease after an hour. it could still be grease though, does a couple lil drips while its parked, but it wont looked splattered about because grease stays. i hadda blob of grease on the inside of my winter beaters rim for 4 months and it didnt move or deteriorate. so if you touch it, and its definately not grease, then heres my guess. motor oil. leaky oil pan gasket, oil slowly seaps out (i have one) onto driveshaft which goes under rear of oil pan and makes its way to the end of your shaft and gets spun around onto your rims when you drive. oil stains things. im not tryin to be smart or a dick, just applying my education, finally!!
Old 02-20-2002, 08:40 AM
bracer's Avatar
bracer bracer is offline
I would also say CV boot's torn.
I had the same thing, greasy oil shit all over my rim.
Just check your CV boot, you can see or feel fast enough wether that's the problem or not.
WWW.CIVIC4G.COM
Old 02-21-2002, 04:35 PM
I will go check it sometime by the end of this week. I am a busy guy this week :licker: If it is the CV boot, where can I get a new one? Would an autoparts store carry it?
Old 02-21-2002, 11:26 PM
Setanta's Avatar
Brake fleid doesn't eat in straight away. It takes considerable time.
You can get boots from a local dealer etc, but they are a bugger to fit unless you get wrap around ones which aren't that good to start off with. If it is the CVs then check for dirt in there. If it's badly torn then it's time to replace the whole unit as it'll be rooted soon enough.
Ummm... you know you could check your engine's crank and sump seals. If you are leaking and the oil is running down the driveshafts and dripping off the brakes then there's your issue. Not good if it gets into your pads or your clutch though.
'99 PY DC2R
'85 BBS BMW E30
Old 02-22-2002, 01:12 AM
brake dust...i have the same thing on my rims, i just went downstairs and looked, brake dust...really, it is, brake dust...pollish the shit outta them, and itll be gone...
Old 02-22-2002, 02:20 AM
Setanta's Avatar
lol - that's what I said earlier (amongst other options). Damn stuff eats the paint too, and my rims are powdercoated
'99 PY DC2R
'85 BBS BMW E30
Old 02-22-2002, 03:37 PM
I know for a fact it isn't brake dust. Trust me, I have plenty of that stuff. I am pretty sure it is my CV boot. That was my first presumption. I don't want to get the whole freakin' unit replaced again. I got it replaced last year. I am tired of CV joints... I think I am just going to go outside and rip them off of my car right now, that will solve everything
Old 02-22-2002, 03:40 PM
Setanta's Avatar
heheh... kind of hurts the acceleration if you do that
'99 PY DC2R
'85 BBS BMW E30
Old 09-10-2013, 03:04 PM
dikrims dikrims is offline
Re: stuff leaking onto my rims
Looking for rims for sale with 80% discount?
